My Heller AWM600 washing machine is producing masses of black rubber/coated plastic particles, which seem to be emerging from under the base cover. There is also an odour present. The machine is unusable as these particles are being dispersed throughout the wash, leaving lots of remains in the drum at the end of a wash cycle. The machine is two years old. I would be much obliged if you could give me urgent advise regarding this problem. Many thanks, Anne McGuiness
4 Suggested Answers
SOURCE: Heller awm600 washing machine e2 error on spin
BROKEN PIECE OF PLASTIC ON LID CAUSING MACHINE TO THINK LID IS OPEN ALL THE TIME. REMOVE LID, WEDGE BROKEN UP SATAY STICK INTO GAP, REPACE LID AND VOILA!! WASHING MACHINE SPINS AND ALL FOR LESS THAN 15 MINUTES WORK AND A STICK!
Posted on Jan 10, 2010
  • 3 Answers
A far better and safer way would be to replace the lid.
by wedging a stick in you are bypassing a safety feature and a child or person could sustain a serious injury by openg the lid placing their hand into the drum whilst on a fast spin
Posted on Mar 09, 2010
  • 257 Answers
SOURCE: i have a heller awm600
Check your drain hose to make sure there is no kink. Make sure the hose dose not exceed the length of the hose that came with the unit. Check to be sure there is no other blockages in the drain line. If these are all clear you will have to check the pump at the base to make sure there is no obstruction limiting the efficiency, Debris such as toothpicks stir sticks coins etc.
Posted on May 05, 2011
Why do I have plastic particles sticking to clothes in my washer?
Is the machine noisey on a spin? if so probably the drum bearings have gone or the spider {or shaft }broken
Jan 30, 2016 | LG WM2140CW Washer
Magic bullet base is full of particles
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
Sep 18, 2012 | As Seen On TV Magic Bullet Food Processor
I have a 5.5kg Top Load Fisher & Paykel Washing Machine MW512. The clothes seem to come out with alot of dust particles on them. Is there somewhere in the washing machine where it is collecting this...
Hi - are these particles kinda ash grey black in colour? if they are then the bellows have sprung a leak.. unfortunartely the only way is to replace the inner stainless drum.
Inspect the top of the bowl for any signs of structural damage along the grey plastic housing as it contains very fine sand used to counter balance the inner bowl.. on rare ocassions these leaks and give you the particle effect similar to what you've described..
Aug 12, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have a heller awm600 washing machine, even when i only put a light load, the spin cycle doesnt get rid of all the water. I have tried moving positions, the same thing happens whether i use, delicate,...
May 05, 2011 | Washing Machines
RUBBER LINER COLLECTING MOLD
I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Heller awm600 washing machine e2 error on spin cycle. Washes ok but does not spin properly and gives e2 erro, will not continue with cycle. Any suggestions? Thanks kayjay
Jan 09, 2010 | Washing Machines
Door Wont open on my Samsung J845 washing machine
yes its the door mechanism Unplug the machine for 4 hrs the try opening the door.Don't try to force it you will make matters worse
Sep 07, 2009 | Samsung WF203ANW Front Load Washer
The rubber on the speaker surrounds
I have removed all te rubbercoating by using a degrease liquid the they use normaly in the kitchen to clean the oven : It's perfect now .. a clean plastic surface ... just like new !!!
Be careful with other agresive cleaning products , otherwise you demage the plastic surface below the rubber coating .
Try it out it works perfect .
I hope your problem is solved now .
Excuse me for my incorect englisch ... i'm living in Belgium and my motherlanguage is dutch .
Sep 20, 2008 | JVC RV-B90 Boombox
Black soot on plastic in dishwasher
You can get a product called dishwasher majic. It is used to clean the tub of a dishwasher. Big box stores (LOWES, HOME DEPOT) should have it. There is not charcoal in the unit. I suspect is grease from the rubber seal around sump assembly.
Jul 23, 2008 | Maytag 24 in. MDB5600A Jetclean II...
New boiler and o-rings
Do you have any type number on the machine?
Dec 07, 2007 | Saeco Incanto Rondo Fully Automatic Coffee...
Washing Machines Logo
Top Washing Machines Experts
