Question about Sony CDX-SW200 AM/FM Compact Disc PlayerCDX-SW200
I just purchased the Sony CDX-SW200 from a pawn shop and noticed that it doesn't have a red wire attached to the wiring harness coming from the radio? Is this right? Is there supposed to be a red lead coming from the radio's wiring harness, and if so, would I need one to make the radio light up? I'm getting power because the cd ejects and inserts, but nothing shows up on the display screen??? Also, the harness has an orange lead that doesn't seem to serve any purpose? Could it be possible that this radio has the wrong wiring harness??? PLEASE HELP ME!
    Top Expert:
  • Sony Master
  • 12,744 Answers
You bought it from a pawn shop --and you wired it up so you have some sort of wiring instructions -yes it could have the wrong harness for your application but the correct one for some other
Posted on May 01, 2017
KaeZoo
  • 156 Answers
SOURCE: cdx-mp40
You are correct, the unit powers entirely from the red and yellow leads. Your symptoms sound like a unit that isn't getting power on the red (switched) lead. The most likely cause is a blown fuse in your vehicle's fuse box.
Posted on Mar 15, 2007
  • 3 Answers
SOURCE: Can't figure out how to change the time
Press DSPL for 2 seconds
Press the + or - volume buttons to set the hour
press SEL
Use the volume buttons to set the minute
Press DSPL
Posted on Jan 26, 2009
Nomodo4u
  • 863 Answers
SOURCE: I want to install a Sony CDX-SW200 cd player in my
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
Posted on Feb 23, 2010
  • 59 Answers
SOURCE: what is the wiring color code for a sony cdx-sw200
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope that is what you were asking for.
Posted on Nov 08, 2010
kenw392
  • 2226 Answers
SOURCE: I need A new wiring
try pacparts.com
Posted on Jan 21, 2011
Diagram abot wire harness
A wiring harness for the unit is most likely more than you would pay for a used unit at a pawn shop. Most sony receivers have the terminals labeled on the circuit board. If you are lucky, you can find a dead one at a stereo shop or repair shop near you. They didn't name them explode for nothing. Be careful. 25312832-wng3opgl1pug32fsc4t4fc4i-2-0.jpg
Dec 08, 2014 | Sony XPLOD CDX-GT200 CD Player
Wiring diagram sony cdx sw200
First, you need power on both the red and yellow wires AT the radio's harness. Be sure to clip your test light to the chassis of the radio, not to the truck. This will insure the radio is also grounded.
The problem with a test light is it can be lit by less than 12 volts but this voltage may not be enough for a radio to function. It is best to use a DMM (Digital Multi-Meter).
Let me know.
Dec 18, 2013 | Car Audio & Video
What is the wiring color code for a sony cdx-sw200
Nov 08, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
I want to install a Sony CDX-SW200 cd player in my car and need to find a wiring diagram. Where can I find one?
Here you go bud:
Feb 23, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
Need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
Jan 13, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
CDX-SW200 plays the stereo but not the CD's
sounds like you connected the amp turn on lead to the power antenna wire coming from the deck, so the amp turns on when you have the radio on, but turns off when playing cds. you need to connect the amp turn on lead to the amp remote wire.
Jun 11, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Sony cdx-gt21w
If you stop by any car stereo shop, you should be able to purchase a wiring harness that will plug into your car's plug. You can then wire it up to the wires coming from your sony by matching up the standard wire colors.
Sep 13, 2007 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
