Question about Dishwashers
Detergent dispenser lid does not open fully because it is blocked by front of the top rack
  • 901 Answers
Yes it is happening in my machine also. However the detergent will be taken for the wash. You will not find the soap trace also.
But do not keep items close to the lid.
Posted on Sep 29, 2010
Dispenser cover opens detergent not dissolves on 665 elite ultra wash
If you happened to take the rack out, check it. It may be turned around. Sometimes when that happens the rack won't allow the dispenser door to fully open.
Apr 14, 2017 | Dishwashers
Gritty murky crockery powder dispenser has sticky powder after the wash still in it.
Is it the dispenser that has murky powder or the dishwasher?
Dispenser: Is the dispenser being blocked from opening all the way during the wash load? This can happen in some dishwashers if a tall pan or dish is blocking the dispenser from fully opening. Hence, part of the detergent stays inside the dispenser and is goopy/murky/yuckie.
White powder on racks, nonstick spatulas, silverware basket: There has been a recent change in dishwasher formulation that can cause a white residue to deposit. Phosphates have been all but removed from dishwasher detergent. If there is a white residue on the dishwasher racks, etc, try a dishwasher cleaner such as Affresh for dishwashers and then look to consumer union for a new formulation. Be of good cheer: phosphates are very bad for our waterways, fish and fauna. This change was made in laundry detergent about 16 yrs ago.
Oct 11, 2011 | Dishwashers
I have a whirlpool dishwasher DU920PFGZ0 and the detergent dispenser door doesn't open all the way to release the soap
Is there a tall dish/cookie sheet/pan blocking the dispenser door from opening fully? Check inside the rack of the dishwasher to see where the dispenser door lines up.
Oct 11, 2011 | Whirlpool Dishwashers
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
Whirlpool washer overflows at detergent dispenser
Hello, I worked on a problem like this a few days ago. Your problem is going to be a blockage in the inlet to the drum. To fix this problem find the inlet pipe normally located above the door behid a flap of rubber..push your fingers up there to see if you can feel a blockage..If not your going to have to remove the lid of the machine to access the pipe that leads from the detergent drawer to the tub. Look at the rear top of the machine..You will see three screws....remove them and push back and lift the top panel (lid) now you should be able to access the pipe. Pull the pipe off and clean it out, i suspect you will find a sock blocking the pipe :) If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Sep 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishwasher detergent "pacs" dont disolve anymore
Try reversing the bottom dish rack, it's likely blocking the dispenser door because it's put in the dishwasher incorrectly. Also check if there is anything in the back of the rack preventing it from going all the way in.
Apr 05, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
UNDISSOLVED SOAP RESIDUE AND
I have the same dishwasher and kept having soap still in the dispenser at the end of the wash. Someone mentioned this, but what was happening is that the soap dispenser lid was blocked from fully opening by the top rack. You also typically have large pans in this area, so the water spray is blocked from getting under the half open lid well. I started opening the dishwasher after I heard the dispenser latch release, so the lid could fully open. After that, I had no problem with soap still in the dispenser. I started setting a timer to open and shut the dishwasher door about 20 minutes into the wash process (after the latch had released for the 2nd wash cycle), so the soap dispenser lid would be fully open. This was a pain, but it worked. The other thing to be careful of with this dishwasher is to ensure you have pushed the top rack in tight before closing the door. Look at the water connection for the top "spinner" and you will see how the plastic pipe fits up to the supply. If you don't have the rack pushed in tight, you get leakage around the connection and don't get good water spray from the top spinner arms. This can definitely affect the quality of the wash. You mentioned the dispenser lid is open when the cycle is complete, but that is because once you open the door it can fully open.
Mar 26, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
