Question about Braun Health & Beauty
Where can I buy electric shaver lubricating oil?
  • 490 Answers
Any fine or light body oil will work well. sewing machine oil or 3in one oil are good too.
Posted on Oct 07, 2010
How do I lubricate the ice shaver rod-it squeaks and with what kind of lubricant?
If you can visually see the rod, use a few drops of cooking oil. If it leaks into any drink, you wont get sick. Don't use mineral oils.
Feb 29, 2016 | Nostalgia Electrics MOS-400 Counter Top...
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
Should i oil any parts of my norelco 885rx
It is not a bad idea to oil the motor drive and the tree drive gears every few years. A drop of lightweight oil on each end of the motor drive is all you need.
The heads can be lubricated with Norelco shaver lubricant and cleaner. It is found at shaveroutlet.com at the link below
http://shaveroutlet.com/catalogsearch/result/?q=hq110&submit=
Feb 15, 2015 | Norelco Health & Beauty
Are electric razors hard to clean?
No usually come with brush or wash under water
Aug 16, 2014 | Panasonic Linear ES 8003 W Electric Shaver
How to oil the shaver
The only 'oil' that should be applied to your shaver is the Norelco HQ110 shaver lubricant and cleaner found at shaveroutlet.com at the link below
http://shaveroutlet.com/norelco-al80-razor-lubricant-spray-p-255.html
Simply spray a small amount into the shaver head a couple time per week
Jun 22, 2014 | Norelco Spectra 8825 XL Electric Shaver
How should I lubricate the screen and cutter on my electric shaver?
While your electric shaver is running, you should spray a lubricant on the shaving screen in order to avoid the metal to metal binding. You don't need to wipe off any remaining lubricant.
Feb 06, 2013 | Health & Beauty
Where exactly should I place the drop of lubricating oil?
Hi ajkhoudair,
Place the drop of oil on your finger, and rub in a circular motion on all three razor heads (one drop will suffice for all three). Once you lubricate the three heads, turn the razor on so that the oil is able to move into the chamber. It is suggested to do this once every four weeks.
If you have any additional Philips Norelco questions, you can reach Consumer Care @ 1-800-243-3050.
For more information on this product, visit http://ow.ly/5PRIX.
Hope this helps!
Jul 28, 2011 | Philips 7110X Electric Shaver
I have a Rotatract electric razor, HP1601. Do I need to lubricate and if so, how?. Can I still get parts, and if so, where and what?Can I get a manual somewhere. this is a very old razor that I haven't...
I have no way to get you a copy of an owner manual as this is a very old model made before Norelco begnning offering on-line user manuals.
There are some parts available for your shaver. The parts most likely to need replced are the shaver heads and the motor brushes. You will find these parts at shaveroutlet.com. See links below
http://shaveroutlet.com/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
http://shaveroutlet.com/norelco-philips-carbon-brushes-set-p-307.html
It is suggested that all shavers have the heads lubricated. Norelco makes a product for this and it is also found at shaveroutlet.com
Internal lubrication is not often needed but if your shaver is a bit noisy a 3 in one oil can be used. You will need to take off the outer case of the shaver by removing two screws on the one side and one screw on the other. Once the insides are removed, you can remove the two metal clips that hold the gear housing on. You can then remove the gears and lubricate the spindels they fit onto and oil the pinion gear.
Reassemble in reverse order
Feb 16, 2010 | Norelco Health & Beauty
How to lubricate Norelco 3405 shaver?
The sewing machine oil should work fine.
This model has 4 screws on the back. You must push up the trimmer to see two of those but the other two are in plain view. Remove screws with a flat jewelers screwdriver or you can purchase a special removal tool from shaveroutlet.com here:
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Once the back cover is removed, you will be able to see the motor. It is attached to the gear housing by two metal clips. Remove the clips and you can lift the motor out. Apply a couple of drops of your oil to the pinion gear on the 'front' of the moto and a drop to the small indentation on the back of the motor.
If you still have noise. you will need to lubricate the gears. Temove the gear housing by removing the 2 screws that are on either side of the motor. The gear housing will then come off. The front and back of the housing are held together by plastic snaps on the three corners. Gently pry them apart to seperate and reveal the gears inside. Lift the gears out and apply a light form of grease to where the gears fit onto the back of the gear housing. Vaseline should work well if you have nothing else.
Reassemble in reverse order and it should run very quiet when you're done
Jan 26, 2010 | Philips Norelco 8175XL Electric Shaver
Braun Synchro 7680 - "Oil" message
Had the same problem on my shaver too. Bought this product:
http://www.onlineshavers.com/pd_braun_8000_activator_foil_cutter_pack31.cfm
(I know the link says foil cutter, but it takes you to Braun lubricating oil!)
I apply the lubricating oil to the foil etc, then the word "oil" disappears. Then after a while the word "oil" comes back and I apply the oil again and so on, my shaver still performs normally.
Hope this helps.
Feb 12, 2008 | Braun Syncro 7680 Electric Shaver
Health & Beauty Logo
476 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
