Question about Samsung Computers & Internet
When a start my PC , after almost an hour the screen fades suddenly and the mouse and keyboard hangs or i would say my system freezes...then i remove the plug of the monitor only from the power and after waiting for about 20 minutes i put the plug back to power n it starts working again...this phenomenon happens over an over againn...and i am completely fed up with the whole thing....i will be reallly thankful if you are of any help to me....please help me...
    Guru:
  • 1,481 Answers
Guess ur PC is on power saver mode...if ur using Windows....go to the Power option....
how to....
go to Control Panel then look for a Icon called....Display/Double Click/Screen Saver Tab/Click Power Button/Power Schemes Tab/
under the option Power Schemes....click the drop down arrow
chose as per your machine type...
under each setting for power management choose "Never" for all options (Turn Off Monitor, Turn Off HardDisk, System Standby) and save...by clicking "Apply" "OK"....
pls revert back....kindly leave a feedback and rating for this solution...it will help me become "Guru" here at Fixya...
regards...
Posted on Sep 29, 2010
Hang my laptop when we connect the internet
this is a software issue, conflict in software or drivers, came up with similar issue on a Lenovo laptop, came up with blue screen error messages after hanging up. First temporary solution to avoid hanging during start up, allow computer to finish the system start up until it finishes with the desktop displays with out doing any keyboard or mouse activities until you see at the bottom of the screen or on the task bar that the internet connection has been established. Pressing keyboard keys or mouse buttons causes the system to hang up. If it still fails , run MIcrosoft Fixme software to determine the software at fault so it can be removed or repaired.
Dec 24, 2013 | Computers & Internet
I have an msi motherboard b75 ma g43 when i turn my system on the screen freezes at 99 appearing on the botoom right side corner of my screen.my mouse and keyboard are also not working.
Check your RAm and that you have the keyboard connected to a working port. A modern computer will not start(usually) without a keyboard. If your keyboard is a USB one then plug it into the front.
Jul 24, 2013 | Computers & Internet
Mouse and keyboard not working - how do i boot up computer
you may installed the hardware wrong or your system mainboard suffers from critical problem. if its not so remove the mainboard battery and put it again after 15 minutes it resets your system bios.
Jan 16, 2012 | HP Compaq Business dc7600 PC Desktop
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
My acer desktop has been hanging all of a sudden. When i restart the desktop,it takes about an hour for it to reach the home screen and another hour for the home screen to load. When i try clicking on the...
the hard disk on your pc is almost worn out.
you will need new hard disk. Install fresh copy of operating system and loading to home screen will be normal again.
Jan 09, 2011 | Acer AX3950-B3062 Desktop with P206H...
2 cpu and a kvm sharer swith problem.
That switch is power activated - the kb and mouse are assigned to first one that starts and the second pc thinks that it doesn't have neither keyboard or mouse attached and freezes.
Before starting the second pc manually change the assignment.
Feb 15, 2010 | Computers & Internet
My Dell Dimension 4600 needs to be reformatted. The Dell reinstallation OS disk boots up and gets as far as "Windows Setup....press Enter to continue". Then it freezes. I have tried using both the original...
Before you go ahead and try reformatting the system , Please disconnect everything from the system (Except Mouse, Keyboard and screen)
and then try to use the disc to reformat the system. and if it still hangs up or freezes up that clearly seems to be a hard drive failure.
Hope this help.
Cheers!!!!
Jul 16, 2009 | Dell Dimension 4600 PC Desktop
Keyboard and mouse problem
1. You can disconnect the Hard disk then test the system if keybaord and mouse working, then there i s problem with your operating system or RAM.
2. Processor fan will rotate even after system hang up.
3. Check the RAM for cause
4. Operating may need to reinstall
May 25, 2008 | Intel D101GGC Motherboard
Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
Mar 15, 2008 | Acer Aspire 1642ZWLMi Notebook
Keyboard/Mouse Freezes System Sporadically
Wireless routers generally are 2.4 Ghz, as well as the wireless keyboard and mouse. I think there is interference from the router that causes the keyboard and mouse to hang. I had the same problem with my 2.4 Ghz cordless telephones and my new wireless router. Went to 5.8 Ghz telephone and the problem stopped. I'm not sure yet how to work around the keyboard/mouse issue.
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
