What does OE stand for - Washing Machines
  • Washing Mach... Master
  • 8,220 Answers
What is oe standing for
An OE error code suggests that you have a drainage problem with the unit. Check for drain blockages.
Mar 21, 2015 | LG Dishwashers
LG model # LDS5811st stops and displays OE. What does that stand for
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Aug 22, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Code OE
OE is a drain error
  1. The Drain Hose kinked or blocked.
  2. Wiring connection is OK?
  3. The drain outlet of sump is blocked.
  4. The Drain Pump/Motor or circuit is troubled.
  5. Remove the cause of kink or block.
  6. Check the wiring connection.
  7. Measure the electric resistance of Drain Motor. (20-40 )
  8. Replace the Drain Motor or repair the Circuit.
Sep 21, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error OE
thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Jun 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
DISPLAYING OE ERROR CODE
What did the original poster with the OE error find?
An OE error = Dishwasher not fully drained out in spite of 5 min. drainoperation
Remove the cause of kink or block in the drain hose.
Remove the filter and confirm that there is no debris in the sump area, especially the drain pump outlet.
Check the wiring connections, especially in the wiring harness in the door panel. Look for "melting" insulation.
Measure the electric resistance of Drain Motor. (good=20-40 ohms) Replace the Drain Motor if out of spec.
Good Luck!
Jan 12, 2009 | LG 24 in. LD-12BW5 Free-standing...
OE what does this stand for
oe stands for outlet error possible solutions are : drain hose kinked , filter blocked or the pump impellor is blocked.
Jan 02, 2009 | LG WM-2277HW Front Load Washer
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
