Question about Lexmark X1150 All-In-One InkJet Printer
No Blue ink and fading red
My x1150 stopped printing blue ink and the red fades at the end when I run a nozzle clean. I changed the cartridge and it is still doing the same thing. All the other colors are fine.
  • kmada May 25, 2008
    I was hoping to avoid buying a new one. Guess I just have to do just that. Thank you
  • Anonymous May 31, 2008
    Bought a new cartridge and all the colors are fine except I have no blue. Ran all the maintenance programs and cleaned everything; even the interior of the printer,...still no blue!
    mstargate378@aol.com
    Sergeant:
    Champion:
  • 359 Answers
Same thing happen to mine. we tried every possible solution and nothing worked, you will have to buy a new printer atleast thats what we did to save yourself the stress and headache
Posted on May 24, 2008
I have a Canon PIXMA MP250, and it's printing black and faded lines alternatively. (one line black, one line faded black...), sometimes involve blue too.. Anyone can help?
First, are you running low on those ink colors? If not, possibly print cartridges need cleaning. If printer has separate print heads, they made need cleaning.
Lastly, print head(s) may need replacement.
Dec 08, 2014 | Canon Pixma MP250 All-in-One Color InkJet...
My MP600 will not print documents. It will print a scanned document i.e. scan the doc and print from the image. It will print a webpage. It will print a copy it makes but it is blue instead of black....
If colours are faded I would recommend running several cleaning/deep cleaning cycles to try and pull through the colours. It is difficult to say without seeing the print quality, but it sounds like an issue with a partially blocked printhead within the printer.
The printing in blue would suggest to me that one of the blacks in your printer is blocked. Were all 5 colours present on the nozzle check?
Jul 31, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Replaced both print cartridges but print is faded blue
Solution: There are a number of steps you can take to solve this problem (in order of easiest & least expensive first).
1. Make sure you have tried printing a nozzle check and you've carried out all the maintenance tasks that the manual alows (align print head, clean print head etc).
2. Your cartridge may be faulty. Ink cartridges that use non-genuine ink are of variable quality and you use them at your own risk. Even genuine cartridges can expire if used after the expiry date. Bad ink can clog your nozzle. It may be that you have a dried-out ink cartridge - try another one if you have one handy.
3. The print head may need cleaning. There are Canon print head cleaning kits available (use Google top right) or you could try doing this yourself - some people have had success immersing the print head (not the cartridge) in cleaning alcohol, warm water or using compressed air to gently blow through the nozzles.
Apr 30, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Ok, ok, I know it's a no-no to buy after-market ink, but Lexmark
Not all aftermarket inks are bad. To clean your nozzles, I would "bite the bullet" and get new OEM cartridges, run the cleaning utility an nmber of times (at least 3) and the alignment procedure. This should put your quality back to factory standards. Be careful in using aftermarket or refilled cartridges. Check suppliers like LDProducts for cartridges that meet OEM specifications.
Apr 05, 2010 | Lexmark X502N All-In-One Laser Printer
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printing is faded
You may be low on ink/toner. Does the unit have a supplies status monitor or configuration page?
Have you recently changed the ink cart?
May 06, 2009 | Lexmark X1150 All-In-One InkJet Printer
New ink cartridges and still won't print .....streaks and faded ink.
hi ,
-try cleaning it manually - by a lint free cloth and moisten it with water then dub unto the printhead of the cartridge- 4 about 4-6 times,then finish it with a dry cloth-
-then run the cleaning cartridge on the printer
-then print an alignment page
-there is no problem on the printer its just the cartridges
jim
Sep 30, 2008 | Lexmark X1150 All-In-One InkJet Printer
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Lexmark X1150 All-In-One InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
