Question about Dryers
Hi, my amana dryer was fixed by a technician a few days ago. I called because there was no heat but dryer did everything else. Man came diagnosed dryer with a new heating coil. He replaced. Now best is there but takes to long to dry ? I know its not heating vents to outside. They were recently cleaned ?
  • Dryers Master
  • 17,129 Answers
It is possible that the coils replaced have been with low wattage and so the heat generated can be low ,Hence the slow heat for the longer drying time. Please check the correct wattage of the coils and confirm.
Posted on Sep 29, 2010
    Sergeant:
    Champion:
  • 351 Answers
Could be when he put the dryer back the vent didn't line up right or its blocked
Dryer works, but no heat.
Thermostats/thermal-fuses in back of dryer, usaully 2 of them, call a local appliance supply place, should be able to supply them. if electric 220volt, 1 side is 110v for heat otherside 110v is the motor, timer, light, ect.
May 23, 2012 | Kenmore 98702 Stacked Washer/Dryer
Amana dryer NED7200TW quit heating, it appears everything else is working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Amana NED7200TW Electric Dryer
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
I purchased an Amana drier a few years ago and my aunt purchased the exact drier the model #ALE331RAW It heats so hot you can not hardly touch the cloths
too hot??? thas gerenally a sign of insuffecient venting, check for arestricted and/or blocked vent. it cant release the proper amount of heat and its buildingup inhte machine
Mar 07, 2009 | Amana DLE330RAW Electric Dryer
Whirlpool,gas dryer will not heat up the drum rotates
Problem could be the several components in the heating circuit but the thermal fuse is a common failure component. You will need a technician to diagnose this or learn how at repairclinic.com
http://tclaundryrepair.com/home
Feb 19, 2009 | Amana NDE2335AY Electric Dryer
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
