Question about Zenith DVB412 DVD Player
Disc error When I put a DVD in, the T.V. screen shows a spinning DVD and then on the DVD player it says disc error. When I turn the player on it says Hello in the little window and OPEN and CLOSE when I put the DVD in. I have tried several types of DVDs including a CD but it keeps reading disc error. Any help with this would be greatly appreciated. Butterfly227
When i press play on my dvd/cd player it says error
Posted on Feb 01, 2010
  • Dan Newhart Sep 11, 2013
    it's DVD PLAYER FOR aTV NOT A PC .
Won't read regular dvd's
I think local disc cannot read your DVD. Put quality disc into your DVD.
Feb 21, 2014 | LG BD610 BRay Disc Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Portable DVD player .disc error unit spins but says says no disk
Likely to be a classic laser failure. It will require technical person to replace it - try starting with the point of sale and see about warranty etc
Dec 17, 2008 | Televison & Video
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
Disc is not being read,not spinning
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 21, 2008 | Televison & Video
DVD PLAYER PROBLEM
Sounds like a common problem with this trutech brand. There are some possibilities. 1. Laser could be worn out, 2 it could be a bad cable coming from the laser. 3 The home switch for the laser to come all the way back to its "HOME" position could be bad. But usually if this is the case, the disc won't spin at all. And 4th, the spindle motor that spins the disc could be worn out. Causing the disc not to spin fast enough and thus causing an error. Let me know if you want to send me one of these anyone so as i can trouble shoot the problem further. Keep me posted and i hope this helps you out some. Thank you Jay
Oct 10, 2007 | TruTech PVS2119 19 in. LCD Television
DVD pLayer Not spinning DVD's
if your dvd player is 5 years old or more i suggest you trash it and get a new one but if its not try to clean the lens manually with a peace of bond paper. rub the paper gently on the surface of the lens
Jul 13, 2007 | Sanyo DWM-3500 System
Zenith DVB412 DVD Player Logo
919 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
