Lg mw60sz12 rear projection tv no signal on input, tv will not pick up signal on inputs when something is plugged into any of the inputs and that input is selected tv flashes with no signal screen
Hi penny, we two have the same problem. after completly shutting down the tv and unplugging, we removed the RCA/s-video pannel from the back with the three skrews leaving all wires in tact. without touching the mother board i gently pressed in the cords beteween the back pannel and the motherboard. i also had an air compressor and blew out all the dust. PLEASE I HIGHLY RECCOMEND YOU HAVE EXPERIENCED PERSONS DO THIS! touching motherboard components will not only short your tv but it will shock you at a high voltage. we then skrewed in the pannel again and after 1 mintue component along with S-Video worked. i hope this helps you
Posted on Dec 06, 2011
Why wont my rca dlp 50 inch pick a useable signal on any of the inputs
I would if you have not tried it unplug set and a box if used--wait a bit and plug both back to allow each to try to reboot.If "unuseable" signal it means set is not detecting one.If it happens even via rear inputs and removing power etc does not help you have a problem with the main boards that process all signal and have the micro on them.It is unusual to see it via rear inputs but possible---be aware some parts for this set are no longer available.
May 16, 2012 | RCA Televison & Video
Watched DVD cannot return to regular TV just snow what channel should it be on
if you have an external box for the signal (like a sattelite receiver or cable box) then you need to see what input it's plugged into.
If it's plugged into something marked AV1 or something like that, that's the input you need to select to get the TV back. The TV input selection is only for when you have analogue cable or antenna plugged directly into the TV itself.
Jul 30, 2011 | Hitachi 57F500 57" Rear Projection...
Snowy picture, device menu will not come up.
Depending on what devise, (cable box, game system, movie players) the sign of snow is no signal, there are inputs that you hook a devise up to on a TV, you have to change the input on the TV to pick up the signal of the unit, on the remote or TV itself, there with be a(n) "input", "source", "tv/video", or "video source" button that you can choose the same input you chose in the back of the TV.
Jun 28, 2011 | Mitsubishi WD-52628 52" Projection HDTV
I cannot get the RGB input to work. Any suggestions?
I don't know about your particular TV. But on my TV I have go to input on my remote and pick component. On my other TV It has RGB but there is two of them and I have to pick the right one. If this helps give me a positive vote. Thank you.
Feb 28, 2010 | Sharp 55R WP5H 55" Rear Projection...
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
I have a WD62825, it lost power while watching. There is power at the plug in.
Is the grreen light on?..or can be switched on via remote? Plug it out then back in. Green light flashing? If so...you have lost input signal or the tv has reset itself to another input (non functioning). Use Remote to set input (via Net Command) to functioning signal. If the Green light NEVER comes on...it may be major system failure. Be sure remote is set to "TV"
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Does not pick up cable satellite signal
Do you have the satelite hooked threu the regular cable input? If so hook it thru one of the video inputs instead; composite video or component video. the picture and sound will be better and you will be by-passing the problem area of your Tv ( the tuner).
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
DTV
Yes, you will need a HDTV converter box. Your set does not have a ATSC tuner that recieves HDTV signal. Your HD signal will be thru your Component Inputs on the rear jack panel along with audio IN.
Mar 04, 2009 | Hitachi 51F500 51" Rear Projection...
Pc to tv
Try changing the resolution on you computer. That TV may not handle the current resolution setting. You may also have to do something on your computer to turn on the rgb output.
Feb 22, 2008 | LG 42LC2D 42 in. LCD HDTV
RCA PIP
Put something else, DVD player, VCR or a second signal, into one of the other inputs on the unit and switch the PIP to watch that input...
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
