Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I have a 500gig wd drive, i pluged it in and nothing, the computer doesn't detect it. I do not think it is the computer because it detects all of my other hard drives and other things fine. Its full of stuff and the light on the front is blinking. I would love to access this drive can you help?
  • nic_mil_x Sep 29, 2010
    Yea i looked for it through my antivirus software and the antivirus does not read that there is a drive there at all
  • Western Digital Master
  • 27,725 Answers
Have you installed it with USB firewire driver
Posted on Sep 29, 2010
    no and honestly i do not know how, it is not though connected through firewire but a usb cable
  • Brian Sullivan
    Brian Sullivan Sep 29, 2010
    Transfer speed still limited by USB only connection, must step up for FireWire port
    hope this helps
    Problem Solver:
  • 11 Answers
Install a anivirus and scan for it . it might be a virus
  • Rubensam Sep 29, 2010
    you need scan whole computer. if no virus . check your usb wire .is the wire can plug and play type if you need to find new wire and test it
Hello, I just bought a Samsung Home Theater HT-D5500, I connected it a WD External Hard Drive but it is not recognized, I tried with USB memory and it was detected without problems. My WD HD is detected in...
I am having this problem too. I have a lacie stark 1TB hard drive for my mac and nothing happens when I connect it. iPod works fine. But the hard drive. Nothing. Any help would be great.
Sep 18, 2011 | Computers & Internet
MY WD MY NOTEBOOK IS NOT DETECTING DO WE NEED SOFTWARE TO INSTALL FOR DETECTION
It does have software for it, but it doesn't require it. Try to connect it to another computer, and if it works there, see if that computer has any detection software. When you connect something to an usb port if it says "this device could work faster" do not hesitate to click that button. Try all of your usb ports. If you use a mac try connecting it to a pc.
Jun 13, 2011 | Western Digital My Book Essential 1TB...
I purchased 2 WD elements 1TB. I have pluged it
right click on the drive , format it and it should work, if this not solves your problem go to the shop and use your warranty, it may be broken.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
Ibm rev 1.2 cannot detct my lg gdr-h30n dvd rom
Detection should happen when the cdrom is hooked up correctly. Make sure the cable is on right.
Make sure that the jumpers are correct for the way you have it connected.
Older bioses may not see newer drives. The bios would need to be updated if some equipment hooked on is too new.
Another thing to check... see if the drive will work in another computer.
This will determine if the cdrom dvd is good and working.
Sep 09, 2009 | IBM (49P1598) Motherboard
I have a 120GB Western Digital Passport external hard drive and it will not open up on my pc. the WD passport will turn ''on'' and light up and the pc will detect that a usb is plugged in but it will not...
Sounds like your passport is not working anymore. The fact that it wont work on another computer is a solid sign that something has failed in the device itself. Its possible that both of your comptuers have USB 1.1 but I would think this is unlikely.
I would plug it in to one of the comptuers, then go into your administrator tools then open your computer management tool(start>control panel> administrator tools> computer management). This will allow you to see if windows is detecting the drive at all. Sometimes if the file directory is corrupt, or the hard drive is even partially damaged, then it will not show up under "my computer" but it might show up under your computer management tool. If you see it on there, then there is probably something wrong with the hard drive that is not allowing the computer to recognize the device, or at least install it properly. If you dont have any crucial data, you can just simply reformat the drive and it might start to work after that. If you do, then you might have to take the thing apart and transfer the data by using the hard drive like it was just another drive on the computer.
If your computer does not detect the drive at all, not even on comptuer management, then I suspect the drive, or at least the adapter part of it is not working, in which case, you will need to remove the drive from the casing and use it as if it was another internal drive, you might be able to reformat it, then put it back in its casing, and hope that it works after that, but I have never taken a WD passport apart before, so I would recommend doing a google search to see if anyone else has done this before.
FYI, when I bought my WD passport, I bought a replacement plan with staples beucase I knew that with all the traveling I did, I would eventually break it. I have dropped it about 3-4 times only after about 4 months, the thing still works without any problems, but that just goes to show how well WD builds their drives, however, I am sure that if I wasn't so lucky, that I would be calling them up right now asking for a new one.
Jul 03, 2009 | Western Digital WD Passport 250GB Portable...
I have a WD external hard drive USB 2.0 750 GB. It was working just fine for many months, and suddenly, my laptop won't "read" it -- it's not listed/detected in "my computer." I thought there was something...
If the device is recognized and not listed as a driver in the Explorer, then the disk is not recognized as having been partitioned and formatted. You can use the Disk Manager to see if there is anything listed on the disk.
Start - > right-click My Computer -> Properties
In the management console, go to disk management and check your disks. The external disk should be there and then you can see the partitions and drives assigned to it.
If there is nothing on it, your MBR could be damaged, which needs to be restored.
Alternatively you could partition and format it, but then you'd loose the data on it, so that is a last resort.
I think a program called Acronis Disk Director Suite can restore MBR's. Have a look at this external hard disk troubleshooting article.
Jun 13, 2009 | Western Digital Elements powered by WD 320...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Computer won't detect new HDD as master when booting
You can do this!
1. Connect your 500gig drive as the slave of your smaller boot drive.
2. Go to http://freewareapp.com/western-digital-data-lifeguard-tools_download/ and get the Western Digital Lifeguard tools.
3. Run the executable to install WD tools.
4. Run that application.
You'll notice there is a Drive to Drive Copy utility. This will clone your new 500gig drive from the smaller drive. When the utility finishes copying the drive, shut down. Remove the smaller drive, and set your 500 gig drive as master/single. Reboot, and you should be running off the new drive.
It is possible that your old drive was an IDE drive and your new one is SATA. If so, you may need to enter Setup on the reboot, go to the Boot menu, and set the boot device to the new drive type.
Mar 02, 2009 | Computers & Internet
My computer wont recognize my mp3 player
have you checked in "my computer"?
if you have then try resetting it in the back
hopefully that works
May 23, 2008 | Coby MP-C7085 MP3 Player
How do i make all the finals on my wd 500gig not read only so i can write to the folders
How this WD hard drive protects your data:Data Lifeguard™ is an exclusive set of data protection features, including shock protection, an environmental protection system and real-time embedded error detection and repair. WD's Data Lifeguard technology automatically finds, isolates, and repairs problems that may develop over the life of a hard drive.
Data Lifeguard Tools™ are software utilities designed for WD hard drives that work with the embedded Data Lifeguard features to make hard drive installation,diagnostics and repair both simple and worry-free. (Download Data Lifeguard Tools). So download the Data lifeguard tool and try it out
Dec 02, 2007 | Western Digital 500GB My Book World...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
103 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
