Question about KitchenAid Dishwashers
I have an old (not sure what year, 80s?) Kitchen Aid energy saver V Custom by Hobart dishwasher. We opened the dishwasher in the middle of a cycle and now cannot get it to re-start. When we lock it back up and push our normal buttons (Low Energy and Energy Saver/Dry Heat Off) or any other combination of buttons, the dial does not turn automatically and the cycle does not continue. I have also tried advancing the dial manually and still, nothing happens. I have even tried advancing it all the way to the end and then back to where it would start at the beginning, still nothing. Ideas?
flopez
  • 161 Answers
SOURCE: Reset timer for energy saver mode
Every new unit comes with the user's manuals, and every new unit has free tech support from the vendor. What you are looking for is under the "System Settings" found after pressing "Additional Functions".
Posted on Nov 02, 2007
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
SOURCE: Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Posted on Mar 01, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai Energy Saver 1001F
Try this link http://www.rinnai.us/documentation/downloads/Owners_Manual_1001-551.pdf
Posted on Sep 09, 2009
  • 3 Answers
SOURCE: MY KITCHEN AID DISHWASHER MODEL #KUDS25SH CHIKD
Try turning off the breaker to the Dishwasher...See if it resets ...Good luck.,..
Posted on Dec 30, 2009
Manufacture date hobart LX30 H. Serial 23-1044-007. ML 111 4354
If it is before Kitchen-Aid got involved, it is from the era before the 1986 buy-out by Whirlpool, so it is 30 years old at minimum!
Jul 12, 2016 | Hobart Dishwashers
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
How do I reset the CONTROL LOCK on the dishwasher?
If its an kitchen aid dishwasher press and hold "Energy Saver Dry" button for about ten seconds.
If its an kenmore dishwasher press heated dry button and rinse button repeatedly alternatively , it must unlock your dishwasher.
If your dishwasher is of any other brand please specify the same so that i can help you.
Feb 21, 2011 | Dishwashers
Hi there, I have a Tricity bendix dishwasher, approximately ten years old. the other night in the middle of the wash cycle, it went pop, tripped the mains at the board and there was a smell of burning in...
You know, I think the best thing to do would be to replace the dishwasher. It is ten years old and a new one would be more energy efficient and you would save money in the long run.
Jun 29, 2017 | Tricity Bendix Dishwashers
I have an old free standing Maytag portable dishwasher, model number WC504. I just need to know what the differences in the drying options are. What is the difference between Power Dry, Temp Boost, and...
Power Dry uses a little more electricity when drying but does a good job.
Temp Boost will raise the wash temperature to clean better, this uses very little extra energy and works well, it may add a little time to the cycle
Energy saver will not dry the dishes or boost the water as hot as needed to sanitize. It will save about 2 cents per load.
If you need plastics to dry always put them in the top rack and use the power dry. Use rinse aid to help with drying.
May 01, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
AFTER SETING THE WASHING MODE AND LOCKING LEVER I CANNOT ROTATE THE ON OFF DIAL.
Is it an old kitchen-aid? They were actually made by Hobart and you had to select a cycle and then close the door. It was normal only for that model.
Cheers!
Jan 22, 2010 | Dishwashers
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kitchen aid dishwashers model kudi1o1ilbl6 won't function. Cancel light flashes 7 times pauses and flashes 7 times repeat for ever. killing the power did not reset. Advice?
open door, press in rapid sequence the following keys: hi temp scrub, energy saver dry, hi temp scrub, energy saver dry. Close the door until it latches, then open it and depress the cancel key. The lght should clear. It's a beautiful thing.
Aug 15, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
119 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
