Question about Sceptre X7GNAGAV 17" LCD Monitor
I have a Sceptre 19" LCD Monitor and the screen goes dark after one or two minutes. Any sugestion?
  • 11,361 Answers
Look for bad caps first: http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 30, 2010
Sceptre LCD screen ..replace backlite
The lamps are integrated inside the LCD panel. What kind of problem are you haveing with the monitors? see some pictures here: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
Occasionally, when I turn on my computer, my Sceptre X9G-NagaIV (Black) 19" LCD Monitor screen has a dark pinkish hue to it. Adjusting the monitor's controls don't help. If I unplug the monitor from the...
This could be as simple as the video cable isn't connecting securely. You could try replacing the cable or screwing it tighter. We recently had a red tint on an external monitor for a laptop because the cable was loose; since the laptop moved regularly, screwing the connector to the port on the machine wasn't a convenient solution. The other reasons for an odd tint like that is the video card or the monitor starting to fail. Attaching the monitor to a different computer and seeing if the problem repeats will check if it is the monitor and not the video of the computer.
I hope this helps.
Feb 17, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
I've got a Sceptre 19 in monitor with the typical "on for a sec and goes dark". I removed the 6 screws on the back of the case but obviously there is a further step thats alluding me...how to you crack the...
You need to use a plastic scribe to run around the edge of the monitor seam. A plastic scribe is a tool that looks like a knife, but it is not really sharp. Pry into the seam on the monitor and gently but firmly work around the edge until it pops apart.
Nov 06, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor stays black until boot up to Desktop
you use a graphics card as your main output?
and you have onboard graphics output too that you dont use?
if so then you will have to plug your monitor lead into the onboard output socket to see bios. i think you need to go into bios and change which device starts from boot.
it sounds like you have the onboard graphics as your boot device and windows using the graphics card.
Feb 26, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Sceptre DCLCD19+ MONITOR WHITE SCREEN
To me it sounds like the bulb is having a problem with powering up. It may be an issue with the power adaptor or the outlet it is plugged into. Have you tried to plug it in, in other outlets?
Dec 20, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X7GNAGAV 17" LCD Monitor Logo
199 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
