Question about ViewSonic VG930m LCD Monitor
Power light is green but its screen is grey - ViewSonic VG930m LCD Monitor
  • 11,361 Answers
The sreen gives out grey glowing screen only means that the T-CON board is not getting the 5 or 12vdc feeding it from the logic board, or blown fuse due to short circuits in the T-CON board, you need to troubleshoot it.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 30, 2010
Blank Screen on Sony KDL-46XBR4
It sounds that the back light inverter board have the fault. Replace it.
Jan 24, 2013 | Sony KDL-46XBR4 46 in. LCD Television
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Wireing diagram/coloring?
Yellow: Constant Power (+)
Red: Switched Ignition Power (+)
Black: Ground (-)
White: Front Left Positive (+)
White/Black: Front Left Ground (-)
Grey: Front Right Positive (+)
Grey/Black: Front Right Ground (-)
Green: Rear Left Positive (+)
Green/Black: Rear Left Ground (-)
Purple: Rear Right Positive (+)
Purple/Black: Rear Right Ground (-)
Blue: Remote wire
Blue/White: Antenna wire
Orange: Running Lights
Orange/White: Dimmer Lights
Nov 26, 2009 | Pioneer DEH-345 CD Changer
Screen goes black then flashes grey to black.
you are right: resolder the power connector
Nov 06, 2009 | Dell Dimension 8300 PC Desktop
N64 Games Show Green-Grey Screen
Having a green/grey screen shows there is signs of life. I believe the power supply that's the problem. In my recent experience the following solution has helped me:
1.) Wiggle the power supply left & right two times. Now try and see if the Nintendo 64 works.
2.) If not, then disconnect and reconnect the power supply and wiggle the power supply left & right twice. Again, try and see if it works.
I hope it works for you!
Mar 13, 2009 | Nintendo 64 Console
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Grey static then flashing button
Could be your flyback transformer or these caps 2200 mf16v 22035v 33035v. Check the caps for bulging.
Jul 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Open Questions:
ViewSonic VG930m LCD Monitor Logo
123 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
