Question about Fisher and Paykel (IWL12)
When I turn it on it fills intermitantly - fills for 10seconds, then stops and starts continually. I have tried everything - turning on and off and moviing through the cycle. Even filling manually to get water level up - but then nothing happens at all. I have checked all filters on valves etc.. but still not working. I did have some air locks in the hot water system which could have caused the problem but not sure of that one. Can you help
  • doug_mcleod Sep 29, 2010
    The problem has progressed since then. The filling problem rectified itself - firstly by overfilling and flooding the laundry :( - then that sorted. However it will not progress through the cycle - it gets as far as Rinse - pumps our in short busts - the Rinse LED goes off - leaving the amber LED and the Red "Spin" Led on - and then gives a fault beeping. There is no Spin taking place whatsoever.
    President:
  • 1,554 Answers
The Wash Progress LEDs indicates a code when a fault is detected. Some of the LEDs flash to indicate the fault code number. Please specify which among the LEDs are flashing to determine the fault code and pinpoint the faulted part so that necessary actions can be undertaken. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 29, 2010
  • Jahn27
    Jahn27 Sep 30, 2010
    It is fault code number 3 if you are referring to the last two LEDs of the Wash progress LEDs on the right. It means a memory error is found in the Motor Controller Module itself. Unplug the machine for at least an hour to forcibly reset the microprocessor and eliminate the possibility of an electronic glitch. The only viable solution if all else fail is replacing the Motor Controller Module.
2002 Trailblazer security light on, will not crank, replaced steering column
Did you use the original key and lock cylinder? They are coded for the security system.
Dec 31, 2016 | 2002 Chevrolet TrailBlazer
Onga house water pump
It sounds like the starting capacitor has failed. It is the round thing with two wires normally mounted on the outside of the motor. There is also a starting switch that could have failed but it is eaiser just to try the capacitor first.
Jan 21, 2014 | Plumbing
Question: Our Kenmore elite microwave model 66561689101 intermitting on and off. Most of the time it turns off just after it starts and then makes a weird screech sound and then starts back up and is good...
Only thing mechanical on nuker is the cooling fan assembly and /or the turntable platter. Something not turning properly is responsible for screeching noise. And if something is not turning properly there could be a sensor to detect this and shut unit down.
Nov 21, 2013 | Dryers
Whdre526e1ww won't stop filling
Does the washer continue to fill if you turn the dial to the off position or does it keep filling when starting a load?
Oct 17, 2012 | GE WDSR2080D Top Load Washer
Just changed the oil how do i get the change oil words to stop displaying every time i start the car
  1. first turn key on engine off,
  2. within 10seconds of turning the key on fully depress gas pedal slowly to floor three times.
  3. turn the key off.
  4. start engine and message is reset, if not then repeat steps.
Oct 31, 2010 | 2008 Dodge Avenger
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
F&P Smart drive 9
I had the same problem.
You probably only have cold water connected and you need to "program" it for cold water only.
By default it expects both cold and hot water connected and even though you can select "cold" it will still error if not hot water supply is present.
Call Fisher & Paykel customer care and they will tell you how to re-code it for cold only.
Oct 05, 2007 | Fisher and Paykel (IWL12)
Washing Machines Logo
291 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
