I have had the machine in storage for about 12 months and just hooked it up into my new house. I ran the clean cycle which worked but when I try to start a wash the water starts, then stops and just humms. Is this due to the cold water being hooked up to the rain water tank pump?
    Sergeant:
    Champion:
  • 351 Answers
I think that would be the problem they need about 30 lb to work right
Posted on Sep 29, 2010
Won't start
power 120 volt cannot to supply to 230 volt, maximum correction factor for voltage is 15%
Apr 04, 2014 | AO Smith 5 HP 3450rpm R56Y Frame 208-230...
Wf218anw xaa
Are you trying to run a 50 hertz machine on a 60 hertz line?
Jan 12, 2014 | Washing Machines
My Fisher & Paykel smart drive 708 will not switch on. I recently moved house and it worked before I left but I recall that it drizzled while moving so could have got wet. Nothing happens at all
these machines must be truck from the front & transported in the upright position, it may be tilted, but do not not lay flat on its back.
There is about 2 caps of water still in the bucket that the pump cannot pump up a vertical pipe.
Motor controller may have got wet & blown the 4 amp fuse in the board.
You need find a tech to have a look at your machine.
Feb 10, 2013 | Fisher and Paykel GWL11 Top Load Washer
Delicate cycle fills with water but will not agitate
Timer needs cleaning on the delicate relays (points) in the delicate position. Maybe timer failure. Transmission stuck, jammed or failing in that wash mode
Sep 21, 2012 | Estate Washing Machines
Anyone anygood troubleshooting a Whirlpool Washer?
Thats a problem. Did you have the washer laid on it's side when moving? Timer switch would be first look. Hot water not working,but cold is? Mmmm.. Water inlet is pretty simple no real mechanical parts except intake valve for each inlet. Valve could be plugged or stuck closed on hot intake. Temp switch could be bad and that would cause the water intake to shut.I guess, but not usually a problem unless old machine. Make sure the fuse in control panel is intact. Underside of washer is a relay switch called wigwag. If it is bad nothing will cycle, easy fix 10 minutes and $15 in most cases. But check out before jumping to solve. All ways check cheapest parts first. Lid switch would also cause the no start and spin cycle problems.
Mar 09, 2010 | Washing Machines
Washer tub won't stop filling with cold unless tap is off
Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
Nov 02, 2009 | Washing Machines
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Perfoma washing machine won't go through rinse cycle.
Hi
After investigating the logic of the machine and how the timer works, I traced it down to the cold water solinoid rubber stopper It had crud in it and just hummed. After cleaning it out it ran just fine..
This is an easy fix.. If it cant run water it wont go to the next part of the cycle.
I hope this helps. I have more info if required.
Ashley
Feb 07, 2009 | Maytag Performa PAV2200
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Apr 15, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
