Burnt item RCA P56830BL
Picture on projection tv is 6 inches tall and full width of screen, i found a burnt item on the board in front of what i think is the vertical ic the item that burnt has numbers on the side AV R73 KP H7 and is 1 inch long 1/2 tall and the numbers on the top of it are different, AV 056 J 630 can you tell me what it is and also a good source to get one
thank you
  • Jon Morton May 25, 2008
    JV14101 i have pics but am having trouble attaching to this post.....thank you for your help
    i am able to e-mail pics but not attach here. i will send them if you would like
  • 8,617 Answers
Can you give me the PCboard location number of the component? It will be stamped on the PC board where the component is located.
Posted on May 24, 2008
Rca model p56830bl chassis ptk195bl convergance miles out and concave picture top and bottom
the answer is simple, do you have yahoo IM? I can give you free answer here or there, I know what is wrong.
Sep 21, 2011 | RCA P56830BL 56" Rear Projection...
I got sound but no picture on my 52 inch rca floor model tv i sure its the bulbs but not sure how can i find the prices or the rite bulb for it
That set is a 1994 model set. You have 3 picture tubes in that set of which are no longer available or made anymore.
Nov 27, 2010 | RCA P56830BL 56" Rear Projection...
Sound but no picture continued
Vertical output IC is either defective or needs to be resolderd
May 02, 2008 | RCA P56830BL 56" Rear Projection...
Sound but no picture RCA P56830BL 56 in. Rear Projection
Vertcal output IC is either defective or needs resoldering. Do the end of the CRTs (filaments) light up?
May 02, 2008 | RCA D52W19 52" Rear Projection Television
Rca p56830bl picture fade out
sounds like a vertical and horizontal deflection issue..maybe your control board is unhappy.
you inclined to do this work yourself?
Apr 28, 2008 | RCA P56830BL 56" Rear Projection...
Rca p56740bg tv
Most of the screen cover for sets older than 8 years have been discontinued,get the size of your screen leaving about 1/8 of and inch around the screen,you can get your local lumber or hardware store to cut pexie glass to fit,get velcro and apply to sides of screen to attach glass,make sure to sand any sharp sides before attaching.
Dec 31, 2007 | RCA P56830BL 56" Rear Projection...
RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Aug 30, 2007 | RCA P52926 52" Rear Projection Television
RCA P56830BL 56 in. Rear Projection Television
Replace tuner. Verify ==bypass using A/V inputs
Jul 19, 2007 | RCA P56830BL 56" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
