Question about HP Laserjet Cp2025n Printer
I want to print in black color but the printer magenta color cartridges is empty
  • 223 Answers
Try setting the override on, Press the menu, look for system setup and press ok, find the print quality menu and press ok and look for the the override out. set it to on.
Al
Posted on Oct 01, 2010
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Rulds2008
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Won't print black because magenta color is empty
Refill or replace the empty cartridge.
When you ask to print "black", a small amount of magenta is mixed-in.
No magenta, no print.
Nov 11, 2009 | HP Photosmart D7360 All-In-One InkJet...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
HP Laserjet Cp2025n Printer Logo
231 people viewed this question
Seeker5211
Seeker5211
