Question about Waterway Spa Pump Executive 56 Frame 5hp Dual Speed 2 1/2" Intake 2" Discharge
Should there be clearance between the wear ring face and the pump faceplate? After reassembling pump with new parts, I am noticing a 1/32" - 1/8" clearance/play between the two. It would seem that the face (flange) of the wear ring should have minimal clearance and rest against the inside of the pump faceplate after the screws are tightened. Thanks.
  • 990 Answers
No the wear ring should slide freely to cause a seal when pump is on. The water pressure inside the pump will push it into place. Also be sure the large side of the wear ring goes out so when it slides forward it seals.
Posted on Sep 29, 2010
Testimonial: "Perfect advice. Pump is back together and working perfectly. Thanks."
Ring end gaps for B&S 31P777 engine
If the engine the figures are required for is a re-ring using the original pistons it is important to check the amount of wear of the bore and of the piston groove clearance.
Once the ring gap is set to the minimum at an unworn part of the cylinder bore the gap should be rechecked at the most worn part and if the gap exceeds the maximum it indicates an excessively worn cylinder bore.
While this is not immediately detrimental it does mean the piston ring grooves will wear much more quickly and the job will have a shorter life and in some cases a high oil consumption can be worsened.
The piston ring groove clearance - side clearance between the ring and the piston should be 0.0015 inch maximum. It can be expected the top groove could be considerably worn and in that case new pistons would be beneficial or a Cord ring set.
Sep 11, 2017 | Cars & Trucks
My mitsubishi canter 4d32 engine had all its 4 top compression rings broken ie one from each bore what can possibly cause that and what amount of smoke or mist should i expect from the breather after...
As an engine wears the ring lands on the pistons wear also. In addition to ring land wearing on the piston, the bore in the cylinder develops a wear pattern. Has the engine been rebuilt?
If the pistons have worn ring lands and were re-used it may allow the rings (new or old) to twist in the grooves and catch on any ridge in the cylinder, thus breaking them.
When the engine is apart you must check for proper ring land wear. You need to consult the piston manufacturer for proper wear specs, typically around 0.006in.
If you're getting a visible amount of smoke/oil from the breather after the rebuild something is not right. The rings are not seating. I would definitely recommend boring/honing the cylinders and going with a new set of pistons/rings so you don't have to pull it apart again. A little more now can save a lot in the long-run.
May 06, 2011 | Mitsubishi Pickup Cars & Trucks
Excessive fuel consumption on vw caravelle 2.5i
Clogged PCV Valve
The main purpose of the PCV (positive crankcase ventilation) valve is to recirculate blow-by gases back from the crankcase area through the engine to consume unburned hydrocarbons. Blow by is a mixture of air, gasoline and combustion gases forced past the rings on the combustion stroke. The PCV system usually has a tube leading from the crankcase to the carburetor or intake manifold. Vacuum within the engine intake manifold pulls blow by gases out of the crankcase into the combustion chamber along with the regular intake of air and fuel.
Worn Piston Ring Grooves
For piston rings to form a good seal, the sides of the ring grooves must be true and flat - not flared or shouldered - and the rings must have the correct side clearance in the grooves. Normally, automotive ring groove side clearance should not exceed .002-.004. As the pistons move up and down, the rings must seat on the sides of the grooves in very much the same way that valves must seat to prevent leakage. New rings in tapered or irregular grooves will not seal properly and, consequently, oil will pass around behind the rings into the combustion chamber. Worn grooves are usually flared or tapered causing increased side clearances which permit more than the normal amount of oil to pass the rings into the combustion chamber. Excessive side clearances also create a pounding effect by the rings on the sides of the piston grooves. This promotes piston groove wear and, if the condition is not corrected, breakage of rings lands may occur.
Cracked or Broken Ring Lands
Cracked or broken ring lands prevent the rings from seating completely on their sides and cause oil pumping by a process similar to that described in #7. In addition to this, they also lead to serious damage to the cylinders as well as complete destruction of the pistons and rings. Cracked or broken ring lands cannot be corrected by any means other than piston replacement and this should be done as soon as there is the slightest indication of a crack.
Worn Valve Stems and Guides
When wear has taken place on valve stems and valve guides, the vacuum in the intake manifold will draw oil and oil vapor between the intake valve stems and guides, into the intake manifold and then into the cylinder where it will be burned. If this condition is not corrected when new piston rings are installed, an engine is likely to use more oil than it did before because the new piston rings will increase the vacuum in the intake manifold. When gum or deposits on the valve stems are removed - a procedure recommended when overhauling an engine - the seal previously formed will be removed and leakage will be more pronounced. This is particularly true on overhead valve engines where loss of oil may occur on the exhaust valves as well as on the intake valves. High oil consumption caused by too much valve guide clearance can frequently be cured by reaming or nerraling the valve stem. In some cases new valves may also be required. Use of a permanently bonded valve stem seal will give added insurance against oil leakage on complete engine overhauls or on valve jobs. Large Oil Leaks Leaking valve cover gaskets, leaking crankshaft front and rear seals.
Apr 24, 2011 | Volkswagen Microbus Cars & Trucks
How do you change the oil pump in a 1995 Lumina van with a 3.8?
REMOVAL
  1. Remove front cover.
  2. Remove oil filter adapter, pressure regulator valve and spring.
Fig. 16 Oil Pump & Housing 42162079
  1. Remove oil pump cover attaching screws, then the cover and gears, Fig. 16 .
INSPECTION
  1. Check pump cover and housing for cracks, scoring, porous or damaged casting, damaged threads or excessive wear or galling. Replace as required.
  2. Check pressure regulator valve for scoring, burrs or sticking in valve bore. Replace as required.
  3. Check pressure regulator valve spring for tension loss or bending, replace spring as required.
  4. Check gears for chipping galling or excessive wear, replace as required.
Fig. 17 Oil Pump Inner Gear Tip Clearance Inspection 42162080
  1. Measure oil pump inner gear tip clearance, Fig. 17 . Maximum clearance should be 0.006 inch.
Fig. 18 Oil Pump Outer Gear Diameter Clearance Inspection 42162081
  1. Measure oil pump outer gear diameter clearance, Fig. 18 . Clearance should be 0.008-0.015 inch.
Fig. 19 Oil Pump Gear End Clearance Inspection 42162082
  1. Measure oil pump gear end clearance with gear dropped in housing, FIG 19. Clearance should be 0.0010-0.0035 inch.
  2. Measure pressure regulator valve for valve to bore clearance of 0.0015-0.003 inch.
INSTALLATION
  1. Lubricate all gears with clean motor oil, then install gears in housing.
  2. Pack pump cavity with suitable petroleum jelly.
  3. Install pump cover and cover attaching screws. Tighten cover attaching screws to specifications.
  4. Install pressure regulator valve and spring.
  5. Install oil filter adapter using a new gasket, tighten oil filter adapter attaching bolts to specifications.
  6. Install front cover on engine. During front cover installation, ensure inner pump gear is properly engaged on crankshaft sprocket.
Jan 29, 2011 | Chevrolet Lumina APV Cars & Trucks
I have Aquaflo XP2 3 HP pump. I have removed old seal and need to install new seal. I have 2 seals, one with a spring in it that goes next to the impeller and another that has a black end and a white end....
Thank you for posting your question here on Fixya.com.
The rotating assembly, with the spring, goes on the back of the impeller with the shiny carbon face away from the impeller. That face mates to the white ceramic face of the stationary portion. The rubber (black) boot seals the white ceramic into the pump housing. The cardboard 'ring' is provided to allow you to press in the stationary portion without touching it. You DO NOT want to touch either seal face (The shiny parts that rub against each other once you are done). Doing so can cause a brand new seal to leak.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 13, 2010 | Aqua Flo AQUA-FLO #200 SEAL, REPLACEMENT -...
Bosch excel check water fault
hi try thisStep 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
Sep 13, 2008 | Bosch Dishwashers
New face plate
Google California Electric Service in California, they are on Burnett Ave. Sorry I am having problems posting solution with my ISP connection.
Aug 04, 2008 | Rowenta DG-980 Iron
PIONEER DEH-P7700MP/P770MP CD/MP3 Faceplate
do you want the detachable face or the case to hold the detachable face?
Here is the detachable face at the Pioneer site:
http://parts.pioneerelectronics.com/part.asp?productNum=XXA7322
Here is the case for the detachable face:
http://parts.pioneerelectronics.com/part.asp?productNum=CXB3520
You might find the face, or even the whole radio with face cheaper on ebay.
Jun 20, 2008 | Car Audio & Video
My DEH-680MP Stopped Working....
I just had the exact same problem today, but the radio responds to the remote and buttons on the face. I can eject cds and everything but the display will not work when the face is up. I cleaned the contacts on teh face pice with no resolution to the problem.
Mar 14, 2008 | Pioneer DEH-P680MP CD Player
Waterway Spa Pump Executive 56 Frame 5hp Dual Speed 2 1/2" Intake 2" Discharge  Logo
177 people viewed this question
Top Waterway Garden Experts
Mike Raino
Level 1 Expert
john h
roeb
Are you a Waterway Garden Expert? Answer questions, earn points and help others
