Question about Plantronics CS70 Wireless Headset
My headset quit working. It's dead - is there a battery that I should be changing?
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Unfortunately the battery in the headset is not replaceable. But you can purchase a replacement headset to use with the base. Here is a link where you can buy the replacement headset:
Plantronics CS70 Replacement Headset
Good luck from Headsets Direct!
Posted on Nov 01, 2011
HOW TO CHANGE BATTERY HEADSET H500
Why do you think you need to replace the battery? A common sign that your Motorola Bluetooth headset needs a new battery is when you repeatedly hear five quick high tones in successive, one-minute intervals. Another symptom of a low or dead battery is when you try to scroll to Power and your headset doesn't come on. The Motorola H500 headset has a long battery life, but the battery eventually will go bad. Unfortunately, the battery is integrated as part of the headset's circuitry and should not be replaced by its user. Motorola strongly advises against trying to change the battery. Attempting to replace the battery voids the headset's warranty. By sending the headset to Motorola for repair, you can have a new battery installed without the risk of damage to your equipment.
But you can try the following at your own risk:
Locate the battery door at the rear of the headset and open it.
Remove the old battery. Install a new battery to match the plus and minus illustrations on the battery compartment. Shut the battery door back in place.
Select "Menu" on your phone. Select "Settings."
Select "Connection," "Bluetooth Link," and "Setup."
Select "Power." Select "Change."
Select "On," and then press "Select."
Press the "Call" button and hold it down. Release it when the LED light blinks.
Oct 11, 2014 | Motorola Mobility Universal Bluetooth...
CS55 headset battery was dead (app 1 1/2 years of service). I replaced it and fully charged. Worked fine for 3 or 4 days. Now, won't charge. Tried the system reset and power cycle, no...
On your base there are the numbers 1-4. Put the # 1 in the 3 O'Clock position like a clock. Try putting the letters that are in the bottom on B.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics CS55 Wireless Headset
Have not use the bluetooth headset(Model: LG HBM-760) for more than a year. Unable to charge the headset now, suspect headet internal battery dead, please advise how to replace the internal battery? Thanks
since you have not used it for more than a year, it only mean that the battery is totally drained, you just have to be a bit patient charging it. just wait til the light gets on. if after an hour or so and it's still the same, then it's time to change the battery or the headset itself.
Aug 06, 2010 | LG HBM-760 Bluetooth Headset
No Sound/No Power
I used your site to research the problem further. I found an answer which recommended rubbing the suspect terminal lightly with a pencil eraser. It worked! I now have battery power and my headset works fine.
Nov 30, 2008 | Bose QuietComfort 2 Consumer Headphones
No sound. Will not play ringtown anymore.
Sounds like your battery is dying and the unit is saving energy.
Mar 13, 2008 | Motorola Mobility H700 Wireless Headset
Battery
A fully charged battery should last up to 4 hours if it's being used A LOT! But I lost mine and it was in standby mode for pretty close to 3 days and when I found it I was still able to use for quite awhile before charging it again.. So yes, it sounds like it had a weak battery..
Oct 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Plantronics CS70 Wireless Headset Logo
101 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
