Question about Sylvania SRC22134 13 in. TV/VCR Combo
Need remote control code for sylvania 13" combo
wyoed1
  • 211 Answers
SOURCE: sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
jessee007
  • 306 Answers
SOURCE: sylvania 27 in. tv/vcr/dvd combo remote code
find out who sales sylvania, look at what other tv they sale and try there codes. sears is good for this to.
SOURCE: Sylvania 6313CB 13" TV/VCR replacemnt remote
The DirecTV VCR codes for Funai (the manufacturer) work axcept for volume!
Posted on Nov 27, 2008
  • 56 Answers
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Posted on Jan 14, 2009
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Posted on Jan 16, 2009
I need a remote control for a sylvania 6513DG tv
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
Nov 25, 2013 | Sylvania 6513DG 13" TV/DVD Combo
I need help locating a code for a universal remote fo my tv it is 6113cb tv/vcr combo
hi,
Try the following codes
if you have four digit universal remote then codes are
0054, 0030, 0020, 0096
If you are using three digit universal remote then codes are
054,030,020,096
ok
Jul 07, 2011 | Sylvania 6313CB 13 in. TV/VCR Combo
I'm using a ge universal remote and cnnot get the sylania model 6513 DF to work
Hello
You haven't described anything about the model number of GE remote. Eventhough it is universal remote, it will have a model number. Model number is necessary for us to give you correct codes. I hereby give you code for Sylvania combo. Check it with.
0456
The code for Sylvania TV/DVD combo with GE RM 24912 universal remote is:
456
Check this code [456] with your present GE remote. Sometimes it may match. OK.
Jun 04, 2011 | Sylvania 6513DF 13" TV/DVD
I need the remote contol code for a sylvania 6313cb 13in. tv/vcr combo
Hello
Universal remote code for Sylvania TV/VCR Combo is:
0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
May 31, 2011 | Sylvania 6313CB 13 in. TV/VCR Combo
I need the remote codes for my sylvania model 6420ff
hi! i have here a couple of codes for your sylvania TV, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483. this is for sylvania HDTV 1046, 1465. this is for the tv/dvd combo 1150, 2092, 1464, 2408, 1465, 2260. this is for the TV/DVD/VCR combo 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147. this is for the TV/VCR combo 1145, 3095. hope this helps!!!! goodluck!!!
May 14, 2010 | GE JASRM24912 Remote Control
Need the code for Sylvania tv
May 13, 2010 | One For All URC4220 Remote Control
Looking for the code for sylvania tv/vcr combo with a radio shack 3 in 1 universal remote
with most combo's try the VCR codes and then also program the tv code for the volume controls
if you are missing the programming instructions go to the RS website - support
Mar 14, 2009 | Sylvania 6313CB 13 in. TV/VCR Combo
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Sylvania SRC22134 13 in. TV/VCR Combo Logo
243 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
