Question about Thomson 27901GE1 2.4 GHz 1-Line Cordless Phone
The screen display only has partial numbers and letters showing, like the battery is not charged or something. I can not read the caller ID or the number dialed. I love the phone.
Need a caller ID that hooks up to land line phone line and shows on television screen.
Contact your phone service provider to setup caller ID and ask them if they do the TV service as well
the service provider has to enable caller ID before any plug in box will display the number there is a charge for the service depending on the package you have
Dec 11, 2016 | Lands Phones
Call display shows time but not caller number
You also must subscribe, with your local phone company and have caller ID, it is a feature and they do charge a monthly fee for it. If you do have that feature and are still having trouble,
Feb 04, 2014 | NorStar T7316E Corded Phone
When there is an incoming Call, the display shows,
You must have caller ID provided by your local phone company for Call ID to work. This is an additional charge on your phone bill.
Feb 21, 2012 | Office Depot Ativa D5765 58 GHz 1Line...
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
No Caller ID on display
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
that should do it providing you have caller id service though your local telco provider.
Mar 25, 2009 | NorStar T7316E Corded Phone
CALLER ID
I just got off the phone with a GE rep, they said to unplug all phones from the wall for 15 minutes, then remove the batteries and put them back in the opposite way they came out. That will reset the system and fix the problem.
If it does not fix it, you'd need to purchase new phones.
Mar 04, 2009 | GE 25951EE2 Phone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
Caller id display screen
I can't read my caller Id Screen numbers are disappering
Jul 27, 2008 | GE 25951EE2 Phone
Thomson 27901GE1 2.4 GHz 1-Line Cordless Phone Logo
260 people viewed this question
Top Thomson Lands Phones Experts
David Burbee
David Burbee
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
