ASUS K60IRBBBR05 Notebook Logo
Posted on Sep 29, 2010
I have an asus k160 and want to connect it to my big screen. the problem is my big screen has composite and component connections not vga! what cable do i need to connect it to my tv. i want to know how to do it with just a cable not a converter. does my laptop have the capability to broadcast component over vga?
5 Related Answers
Anonymous
  • 33 Answers
  • Posted on May 28, 2009
SOURCE: What do I need to connect an external monitor to an Asus Eee 900a
I HAVENT TRIED IT BUT YOU CAN GO TO www.geeks.com AND PURCHASE A USB TO VGA CABLE AND I BET THAT WILL WORK.
ryancsmith
Ryan Smith
  • 62 Answers
  • Posted on Oct 10, 2009
SOURCE: How can I connect the Asus K50IN laptop to a TV?
if your tv is a newer hdtv it might have a 15 pin female vga connector in the back. I just use a vga cable from my notebook to my tv. make sure the vga cable is female on both ends. works great!
Joey Jackson
  • 59 Answers
  • Posted on Feb 01, 2010
SOURCE: i have used 15 point vga to connect laptop to my
Look at your functions keys. most common is F3 but sometimes another key, it will have a little monitor on it, or two screens with a slash.
Press your function (fn) button and this key, it should toggle between Laptop monitor, External, both.
(this is assuming you want to clone your monitor, which is what you described).
Anonymous
  • 1189 Answers
  • Posted on Jun 07, 2010
SOURCE: What cables do I need to connect my Asus netbook (VGA) to my HDTV
Hi, click on this site it will show you the type of cables you can use; rate the help, if it do, thanks. http://search.store.yahoo.net/cgi-bin/nsearch?catalog=aitech&query=Asus%20netbook%20%28VGA%29%20to%20HDTV%20%28HDMI%29%20Cables&searchsubmit=Go&vwcatalog=aitech
Anonymous
  • Posted on Oct 16, 2010
SOURCE: Hi, I have just purchased
set your tv to be connected to the hdmi...and you can set on your pc to see your monitor on tv or with pc and tv...
Where do you watch movie on a computer
The DV10 lets you connect 3 types video cables. VGA, Component, or RCA composite. Look at your computer to see what video outputs it provides.
If you Google VGA cable, Component, or RCA composite, you'll see what these cables look like.
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
1helpful
I connect my Toshiba Satellite L505D-S5983 to my Dynex flat screen tv and if so what cable do I need? Thanks
In order to connect your laptop to your tv's display you will need a VGA to component or composite cable. The VGA part is connected to your laptop on the left side next to the network jack and then the composite or component part to the corresponding inputs on your tv. Here's a site that sells them just to give you an idea of what you will need. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023503&p_id=2170&seq=1&format=2
You should be able to find a similar cable at your local electronics store.
2answers
My tv is a sanyo ds31590. I need to connect to an acer aspire 5253-bz692 in order to watch netflix. What cable do I need?
You'll need a VGA to Composite or Component Cable. Asuming you have RCA Composite/Component Connections on your TV.
I'll Look something like this:
funnyx_1.jpg VGA to Composite
or
VGA to Component
Make sure you TV has @least one of these 3 colored group inputs in front or in back of it. 1. Composite (Mono): Yellow, White or Red
2. Composite (Stereo): Yellow, White, Red 3. Component: Red, Green, Blue
If you don't have any of those then you'll need This Along with a Splitter.
Hope this helps, if it does then please remember to leave Feedback/Testimonial.
I want to connect my computer to my Vizio TV to watch movies via netflix on my TV screen. If HDMI on TV end, what connection do I need to connect to the back of computer?
What "video-inputs" does your TV have:
* composite video (single cable for video, two cables for LEFT/RIGHT audio)
* component video (RED/GREEN/BLUE cables for video, plus RED/WHITE cables for stereo audio)
* DVI or VGA input
* HDMI input
* S-Video (similar to PS/2 keyboard/mouse, in size, and "round" shape)
What outputs does your computer's video-card have:
* composite (post-and-ring)
* S-Video
* DVI
* VGA
* HDMI
Just match them up.
11helpful
2answers
How do I hook up my hp computer to my lg flat screen tv
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
Turn it on iget audio add video flashis for one second then iget kind of a white or gray screen?
The message you're seeing is part of your monitor's ROM programming. It is its response to an input signal that it doesn't recognize. If someone makes a composite to vga adapter cable, it's because they can sell it, not because it works. While both composite and vga are analog signals, they are not at all the same format. The signal gets to the monitor via the vga connector, but it's still a composite signal. Your monitor is all wtf about it. You can make HDMI to DVI cables, but that's because they carry the same digital signal. There is basically no way to connect a ps2 to a pc monitor that doesn't have composite or component input, unless you spend extra money. That can be on either a signal conversion box, which cost at least $50 and might not work so good, or a capture or tuner card for your pc that can capture the signal and relay it to the monitor as VGA or DVI signal. Either method basically converts the composite/component to vga or digital. There is such thing as a ps2 vga cable, but it doesn't work under the normal ps2 operating system, only under ps2 linux. It's hard to find, too. No point looking for one cause you'd only get to play homebrew games of which there aren't many.
http://www.seekic.com/
http://www.chinaicmart.com/
Connecting latop to tv?
use s-video cable  a little round plug most newer tvs have s-video imput that is standard resulution
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
