Question about Frigidaire Affinity ATF7000E Front Load Washer
Frontloader spins when washing but when it's time for the final spin it won't spin, even if I set it to the spin only setting and still nothing. What to do? Is there a belt or something?
    President:
  • Frigidaire Master
  • 662 Answers
The fault could be with the drain out pump blocked or restricted in some way. Un-plug machine from electrical wall socket.
A small panel at rear of machine reveals the pump, pull out the two pipes (plastic clips hard to get off, slide them sideways), remove wire and un-clip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned. Of course be prepared for a lot water, junk overflow; careful it does not fall on wires.
Posted on Jun 30, 2012
  • Frigidaire Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 29, 2010
The machine will not spin only without doing a wash. How to fix that???
Most machines will do a spin mode even though it does not state it you have to set to a final rinse and spin mode.
good luck
Feb 25, 2015 | Washing Machines
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
Frigidaire Gallery Series Frontloader no final spin
I had the same problem. Here's a link that might help:
http://applianceguru.com/forum2/2937.html
I removed the hoses and pump and found the filter in the hose leading from the washer was clogged with a shoelace, $2.35 in loose change and a few GI Joe issued M4's. :-) Once I pulled that filter out and cleaned the **** the washer runs like a champ.
Apr 30, 2009 | Washing Machines
Set washer to just spin
Set timer dial to the final spin position,approx 8-40 position by clock time you will then hear the pump come on , and it will do just the last final spin.
The spin symbol is marked with a large squirl.
To get a copy of instructions go to www.hotpoint.co.uk
On the list click on Manuals-user guides-handbooks
In the search box enter your washer model number, and download the instructions.
Plz rate my solution.
Thanks
Jan 24, 2009 | Washing Machines
GE front loader will not drain or final spin.
I had the same problem with mine about 10 months ago. It seemed that the washer would take forever to wash a load. Every time we went to check the remaining time, it seemed that it never changed. This went on for about a week. We discovered that the washer was not draining properly. After we took it apart, we discovered that a sock, along with some other items, had managed to find its way into the drain pipe. Once we removed the stoppage, and cleaned out the gunked up piping, everything worked well. If we could only find a permanent solution to the ripping door gasket (I have to buy one today; it's the 4th one!!!!).
BTW - I contacted GE about the problem, via email and phone, and they were clueless and not very helpful.
Apr 14, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
121 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
