Question about Samsung ML 1610 Laser Printer
My printing colour is not dark enough to be readable. I changed another new toner cartridge but the prints were still the same
    Genius:
  • 1,040 Answers
Hi..
Not just the print cartridge but make sure that the "Print Head" is also working fine. ink clogging has not taken place on print head.... Print head is a hardware, on which cartridge is attached.
Hope this has helped you.. Thanks..
Posted on Sep 29, 2010
Printer with new toner cartridge printing too light to see almost
Recover the cartridges, en sure there is no 'transportation tape still on the cartridges, if not gently share the cartridges horizontaly whilst also holding it horizontaly. Try again. If it still points incorrectly send it back for a replacement,.
Nov 10, 2014 | HP Laserjet 3030 All-in-one Laser Printer...
Scx4623f problem with printing right side dark and left side deem
Try to remove toner cartridge and shake, plug in and make a self test print. if not work, you need to change new toner cartridge to make sure that the problem is not with printer itself.
Feb 11, 2014 | Samsung SCX4623F AllInOne Laser Printer
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
MY CLP-300 PRINTER IS NOT PRINTING BLACK TXT WELL (OTHER COLOURS FINE) DESPITE HAVING A NEW BLACK TONER CARTRIDGE CAN ANYONE EXPLAIN WHY ?
Spend a little time searching the topic on google and even this post. It appears that this has been a well documented problem since at least early 2008. The problem appears to be the imaging unit. According to several posts, Samsung has replaced several of the units. I purchased my CLP-300 in November 2008 and it worked with no problems until about 8 months in. The black text would print very lightly on the left side of the page about 1/4 of the way into the page. There was also a streak that ran down the page vertically that disrupted the text. I could change the font to any color and it would print just fine. After replacing several toner cartridges, I just began to print in a dark color for many months. After discovering all the posts on the internet this week, I contacted Samsung today with my documentation and evidence. They basically blew me off stating that I was outside of the 1 year warranty period and there was nothing they could do. I was even hung up on by a Samsung employee named Michael. Tonight I plan to take a hammer to it to relieve a little frustration. I cannot understand why Samsung chooses to ignore this well documented problem. Good luck.
Jan 07, 2010 | Samsung CLP 300 Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
OKI c5400
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
  11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
  12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
  13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
Feb 17, 2008 | OKI C5400 Laser Printer
Samsung CLP-550 - magenta bands
I have the same problem. Any solution?
Dec 19, 2006 | Samsung CLP-500 Laser Printer
Samsung ML 1610 Laser Printer Logo
277 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
