Question about Trekstor Datastation maxi t.u SATA 500 GB SATA Hard Drive
IT WORKED WITH MY DESKTOP AND NOW I HAVE A LAPTOP BUT THAT SHOULDN'T MATTER WHAT IS WRONG HERE? HERE IS WHAT IS ON MY TREKSTOR MAYBE YOU CAN GIVE ME A FREE INSTALLATION OR HOW TO GET MY STUFF BACK. THANKS SO MUCH FOR YOUR PATIENCE AND ATTENTION TO THS VERY SERIOUS MATTER. DataSation maxi mu MODEL # IS DSMMU-8-SU 8 WOULD LIKE TO RETRIEVE ALL MY STUFF FROM IT AS I HAVE OLD PICS ETC, WITH MY MOM DYING ETC AND WULD LIKE TO FIND THOSE AND I KNOW THEY ARE ON THERE. IT WORKED WITH MY DESKTOP AND NOW I HAVE A LAPTOP BUT THAT SHOULDN'T MATTER WHAT IS WRONG HERE?
  • Chris Hingee
    Chris Hingee Sep 29, 2010
    Was this SATA hard drive inside the desktop computer?
    or
    Is the hard drive and external USB storage device?
3 Suggested Answers
computus
  • 487 Answers
SOURCE: Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Posted on Jul 10, 2010
bronk50
  • 27725 Answers
SOURCE: My computer does not reconize my Trekstor
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Oct 04, 2011
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Computer does not recognize my trekstor external harddrive now.In the past it reconized it. Please help. Thanks Seen
abdiasdad74 I know the post is 8 years old and no one might read it, but his fix actually worked - no joke. I tried the fix on 2 laptops and when I did what he said, it worked. cool :)
Feb 22, 2011 | Trekstor Computers & Internet
Unfortunately I dropped my Trekstor 500GB hard drive on the floor and now it registers as a removable disk with message "please insert disk into removable disk". My computer is a Windows vista. Can the...
An external unit has two main parts:
* the disk-drive
* the USB-to-disk-drive adapter
In your case, the adapter seems to be working OK.
But, when Windows tries to read the 'table-of-contents' from the disk-drive, it cannot,
and so you get the 'please insert' message.
You might want to disassemble the unit, and remove the disk-drive,
and connect it as a 'slave' disk-drive in a desktop computer,
just to bypass the adapter, to see if the disk itself can be read.
So, about 0.1% of the blocks on the disk-drive are 'unreadable'.
This means that the other 99.9% of the disk-drive _could_ be readable,
namely all your files.
Search online for 'DATA RECOVERY' software -- it reads through the blocks on the disk-drive,
block-by-block, trying to 'stitch' blocks back together (like assembling a jigsaw puzzle) to
reconstruct the (unreadable) table-of-contents, and thus make it possible to copy the files
from that drive onto the 'C:' drive of the desktop computer.
Oct 06, 2010 | Trekstor Computers & Internet
My hdd trekstor 1 tb duo w.u
If your HDD is brand new, maybe it is not formatted yet. Goto Control panel>Adminitrative tools>Computer management>Disk management. be sure not to mess with your fixed hard drives. Scroll down to to find the drive that is unpartioned. Right click and select make new partition. Follow the instructions of the wizard until the drive is partitioned and formatted.
This should solve your problem.
Apr 24, 2010 | Trekstor 88470 DataStation duo w.u 1TB...
No sound when plugged into TV
Me also. Have you found a solution yet?? They play fine on my laptop but only the video plays on the Trekstor
Jun 12, 2009 | Trekstor 88570 MovieStation maxi t.u 1TB...
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
When ever try to use TrekStor DataStation External Hard Drive with my desktop PC (Windows XP), it shows error. Device has malfunctioned. On the other hand it works fine with my laptop (Windows XP). Can't...
well try running install new hard ware! xp is really propritory !!l it doent like to be put on different machines because it wants oem ## an i think it notes ur machine id # an when u move it to different machine it dont work!i move hard drives around from several machines! an it seems if its xp u have to reinstall xp on the new machine!
if its melinum or 2000 u have no problem! xp is a weird animal! well good luck an merry christmas!
dr fred!
Dec 16, 2008 | Computers & Internet
Laptop unable to detect Trekstor HDD
check the jumpers of HD, they must be set on master
Oct 19, 2008 | Trekstor Computers & Internet
Re: TrekStor i.Beat Pink (2GB, pink) not working
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Aug 13, 2008 | Trekstor i.Beat MP3 Player
Trekstor Storage device
I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
May 03, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Trekstor Datastation maxi t.u SATA 500 GB SATA Hard Drive Logo
61 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
