Question about Kenmore Elite 45986 Front Load Washer
TROULBING SHOOTING FOR A FRONT LOADER KENMNORE ELITE 31T
MY FRONT LOADER HAS CODES ON IT,, F11 AN A LF
  • Anonymous Jun 14, 2008
    i have a f11 code on my washer. need help
    President:
  • 1,314 Answers
Check the screans on your water valves lf is a long fill Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit
(MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
• Check Wire Harness thats the f11 error now if you pull the top off the washer you will find atech sheet in an envelope with troubleshotting procedures
Posted on May 25, 2008
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    LF appears after my maytag front loader is washing for about 4 min. We took the screens out, cleaned out and swapped ends of hoses from washer to the water valves. Still not working. Washer only a yea
    LF means long fill....if the flow meter does not detect
    the correct amount of water entering the machine the
    code will appear. Google Maytag front load washer
    LF code...there are several links including a video
    that should help you solve the problem.
    Regards,
    Dennis
    Oct 05, 2014 | Maytag Washing Machines
    Whash machine
    The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
    If the washer starts to fill but the drum NEVER moves, your MCU is bad
    If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
    If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
    Thanks
    Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
    Thanks
    Aug 19, 2011 | Kenmore Front Load Washer
    I keeg getting the dreaded F11 anf DL code!
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    PLACEHOLDER FOR ART
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, then call for service.
    Take care
    Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
    I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
    F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
    Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
    Stops on spin cycle and gives a f11 error code
    F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
    Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
    My Kenmore Elite front loader HE3 washer will not start.
    The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
    Eric
    Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
    Resetting washer after the problem is fixed
    Did you unplug the washer at any point while you were repairing it? Normally, to reset some minor glitches with the washer all that is required is to unplug the washer for at least 30 minutes. This will reset the CCU. If you had the power secured, the problem SHOULD have gone away with the installation of the new door latch. Unless...you purchased a defective door latch, or have a faulty wiring harness. What was the error code you originally experienced? The reason I ask, is because if this is a Kenmore Elite Front Loader as the one pictured above, there is no "lf" error code. "Fdl" and "Fdu" error codes are usually the indication of a defective door latch. Could you please post back and clarify this information for me?
    Sep 28, 2008 | Kenmore Elite 45986 Front Load Washer
    When washing, it stops and says F11. What does that mean?
    F-11=Serial Communication Error
    Communication between the Central Control Unit( CCU)and the MotorC ontroUl nit
    PotentialCauses
    . CheckW ireH arnessc onnectiontso the MCU.t he motor,a ndC entraCl ontrol
    Unit (CCU)
    . Checkt he Drives ysteml or anyw orno r failedc omponents
    . ReplaceM CU
    . ReplaceC CU
    . Replace Motor
    . ReplaceW ireH arnes
    Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    316 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
