Question about GE Spacemaker JVM1640SJ Microwave Oven
Won't heat Hi, I have a GE XL1400, model # JVM1450WA001, Serial # VT912779S microwave that doesn't warm up anything. All the controls seen to be working ok, it just stop warming anything. One of the last times it was used I heard a popping noise behind the control panel, it hasn't worked since. Any help would be appreciated. Alan
  • 1 more comment
  • OnoAl May 27, 2008
    Thanks for the info. We are searching for a new microwave tomorrow.
    Alan
  • Anonymous May 29, 2008
    I also have a Spacemaker model JVM 1650wB004, serial # HZ969634S manufactured in May 2000. When you put the microwave on, it makes a loud buzzing noise, the controls work but it does not heat anything up. I checked the breaker and outlet and they are both working. Is this also a magnatron problem? If so, it seems that microwaves should last longer than 8 years especially this type which sits above my oven/stove and was not cheap to buy plus I had to pay to have it installed!
  • Anonymous Jun 04, 2008
    I also have a GE Spacemaker Model JVM1640BB003. The numbers seem close maybe a small feature difference. Ours was manufactured in June 2000. Everything seems to function properly execpt there is no heat. I too here a slight popping sound every few seconds behind the control panel.
    Guru:
  • 859 Answers
The Microwave's "Magnetron" is what heats things up. This is true for all Microwave's. The magnetron is normally on the left and sends excited electrons across the interior. Those electrons bounce around inside until their energy is spent.These excited electron 'waves' are slightly larger than the hole openings in the front door glass panel black grid. Usually, when a magnetron goes you would see and hear some popping and witness some arcing inside the interior. However, you may not have been nearby when this happened. Since you heard popping behind the control panel, you probably have electronic failure in the control panel and that failure may have been precipitated by the magnetron or not. In any case, it is very dangerous to disassemble a Microwave and access the magnetron unless you are trained and have been qualified to do this.
With the cost of Microwaves having stabilized and also being quite low compared to 20 years ago, I would take it to a warranty service provider in your area that also sells them, such as Home Depot for example. That way, if it is too costly to repair compared to a replacement cost you can shop for a new one and may even get a discount should you ask them to give you one.
Sorry for the apparent bad news but if you feel this is the answer you're looking for please rate this solution as fixed or helpful. It means a lot to those of us who work for you in the free area instead of for a fee.
You can phone or write this address below for questions regarding your warranty or warranty repairs. Othewise, you can shop online for a replacement at homedepot.com or sears.com
Posted on May 25, 2008
I have a kenmore elite microwave and it keeps giving an F9 error message. what does this mean? need help it won't heat
Posted on Nov 17, 2008
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Model XL1400. LAst night quit heating. Everything else appears to be working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400 model # JMV1440WD. Everything works fine but it will not heat anything. Any suggestions?
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave has power but does not heat the
this could be minor to major . most common is recti and cap / and not too expensive to repair but it might be the mag and thats big bucks . . but still worth repair .. ****
Jan 04, 2010 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Oct 10, 2009 | Microwave Ovens
GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating
The magnatron capaciter is burnt out (this is what heats the food!) it can be replaced but it may be cheaper to buy a new oneYjis should fix ya!
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
366 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
