Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Stop working, I just brought it on 1 month ago.
  • KitchenAid Master
  • 17,130 Answers
You have to trace from the power cord to the motor the supply .You will need to see where the problem is to cut power .
it can be a reset switch( if available in the unit), the main switch control.
if not it can be the motor, make sure the bowl locks well to latch the safety switch as some models the motor wont spin otherwise.
Posted on Oct 01, 2010
Kitchen Aid Classic Stand Mixer beater stops when it touches anything.
Very much the symptom of a worm (follower) gear needing replacement. Three are videos of this posted on the net and you can find the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 09, 2013 | KitchenAid K45SS Classic Stand Mixer
Preeti mixie stopped working
I know it is kind of late to answer this, but those who are looking anew for a solution to this problem might find this helpful so writing my experience. I also brought a Preethi mixie, 110V from India and in less than two uses of about 5-10min it stopped. I searched everywhere for a solution and even called service center in Chicago (yes, there is one in Chicago, IL) and finding it difficult to go there and get it repaired, I dared to open it.
I am glad I did as I noticed a connector wire (with a plastic seal/insulator) is burnt. It is a simple fix and I cleaned the burnt part and carefully exposed the wire a little bit more and connected it back to the other wire as it is supposed to and put the insulator back in its place. I started the mixer and its working now :)
I have been using it for a month now since I fixed it to make dosa batter, chutneys etc and it is still working. So I think this is the problem most of us had with mixer not working after few minutes of usage and even the overload button not working. Try this and let me know if this solved your problem.
Happy Cooking!
Jan 13, 2012 | Food Mixers
Philips food mixer HR2970/C : My elderly grandparents brought a Philips food mixer HR2970/C many years ago (possibly 1970/80's) & after a long period of unuse, have now started to use it again....
I believe this product is much older than any of the manuals that Philips currently makes available on their website. Suggest you try sending a note to their customer service. Contact information here:
http://www.support.philips.com/support/contact/contact_page.jsp?userLanguage=en&userCountry=sg
Mar 23, 2011 | Food Mixers
I brought an MX-AC300 PANASONIC mixer grinder from india to usa.its not working.it's not start even once.can any one help me out on this .i used voltage coverter also.
did u check it( i mean whether it was working) in india if not look in to the warranty period and find out what u can do.. i have bought the same mixer and i'm going to take it to finland in a couple of months.. at present in india its working fine.. and one more qn is it the first time that it's not working.. or it stopped working.. coz too much of rotating might even harmed the mixer.. remember for this mixer it should not go more than 3 min..
Mar 29, 2010 | Food Mixers
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Sep 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Panasonic Mixer/Blender not working - works only when tapped
It looks like there may be some loose wire connection. Or it may be due to carbon brush probelm. We at Inno Concepts or any of our dealers can diagnose and fix the problem for a reasonable cost. Please contact us at 770-594-1815 or send us an email with all the details to info@innoconcepts.com
For grinding hard vegetables, use thinner pieces not more than 1/2" in any dimension.
Jun 23, 2009 | Food Mixers
Mixer won't start
I have a PDF file entitled "kitchenaid service manual" that I could send you that I got online and can't remember where. If so my email address is mass78337@mypacks.net Send me an email and I'll reply with the PDF enclosed. Otherwise try a google search of the above and you might be able to find it.
It's looks old but covers all the essentials including a wiring diagram
Apr 21, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid 350 stand mixer power problems
I'd check the brushes. The big black screws on the side of the motor casing, easily removed, but becareful when you put them back. Here were some instructions from another site that helped me get them back in right:
The brushes in my model KP50PSBU must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
Jun 01, 2008 | KitchenAid KSM50PR Professional Series...
Today mixer stopped while mixing.
OK, you mentioned everything except the brand. I found on some models of Sunbeam mixers that the speed governor would fail due to the control knob screw being loose.
On that particular model, the screw is behind a stick-on label in the center of the knob. Peel off the label and make sure the screw is tight.
If your mixer isn't a Sunbeam, please advise.
Mar 23, 2008 | KitchenAid KP26M1X Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
95 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
