Question about Philips 42PF9630A 42 in. Plasma Television
I have a philips m# 42pf9630a/37 it has a black line about 3" wide a little to the left of center where do i start i don't have anything to id the bords
  • 2 more comments
  • sparks194520 Sep 29, 2010
    paid cash for tv i have a background in appliance repair. hoping i could fix it my self as there on philips repair around here jim
  • sparks194520 Oct 08, 2010
    tv guys around here only work on what thay sell
    22578 i am in the stick the appliance co i work for repair the guy there want look at it because we sell rca and zenith
  • sparks194520 Oct 09, 2010
    thanks i will try them my son lives in williamsburg . wile i think about it what about the going rate for replace pdp
    President:
  • 2,777 Answers
This is a very nasty problem for sure. It is most likely the actual PDP that is having an issue, and not necessarily a board unless you can see physical damage. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Thanks,
Tim
Posted on Sep 29, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Sep 29, 2010
    Yikes, well replacing a PDP is very very difficult, and most places do it in a special room where no dust or debris can get into the display when replacing. There is noone near you that works on TV's at all? Most places that work on Plasmas could handle such a thing, I understand there are probably no Philips people specifically...
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    Are you certain? What is your zip code I could find someone I would bet.
    Tim
  • Tim Grayson
    It's somewhat far from where you are, but check with :
    Action Electronics
    1507 Richmond Rd # C, Williamsburg, VA? - (757) 229-1880
Philips 42PF9630A/37
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Nov 07, 2012 | Philips Televison & Video
Philips 42pf9630a/37. Software version: bx23u-1.6.0.0-03541. SBY procedure version: 001.008.001.007. No error messages listed. No defective modules listed. 5427 operating hours. Picture size is...
If the image looks normal but misshapen then the Sustain and buffer boards are functional - their role is strictly to transform the image data into direct commands for pixels from the plasma panel.
The shape, size and aspect of the image is encoded in the image data which is determined by the processor on the mainboard which also stores the firmware and the commands, and is used to do the diagnostics. So either the processor is failing and the mainboard will have to be replaced or the image data get corrupted - check the data cables between the mainboard and the sustain boards. If the cables are good then replace the mainboard
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/42PF9630A/Royal+Philips+Electronics/Philips/996500038481/New.aspx
Sep 17, 2011 | Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
I have 16 horizontal lines about 7 inches from the bottom of the screen. They are about 1/16 inch wide.
Are the lines visible on every xhannel or do they move and appear and diappear with channel changing? are the lines black?
Feb 16, 2010 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Help
On Philips LCD and Plasma TV's you can center the picture left and right and also vertically. Use the round joystick in the center of the remote to see of you can shift the image to the left.
Dec 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42PF9630A 42 in. Plasma Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
