Question about Bugaboo Cameleon Jogger
Hi there, I have noticed that my chassis is bent on my chameleon after only 6 weeks of use. It makes it difficult to hook the rain cover on one side. Who will service/repair in Australia? Would this be a warranty issue?
    Guru:
  • 541 Answers
Bugaboo has a 2 year warranty provided you have your documentation IE a dated proof of purchase. I'm assuming you did not buy it in Australia. The question that will be asked is how did it get bent? I'd like to know as well as they are a strong frame but the center hub it all pivots around needs to be looked after. Try emailing lisle@karlisles.com.au he'll put you on to the closest place to return it. They don't repair they just replace it with a new one. Karlisle's Pty Ltd
2 Haran St, Mascot.
NSW 2020 AUSTRALIA
Ph: 1300 308 435
Fax: (02) 8079-6859
Posted on Nov 06, 2010
Quinny buz won't collapse
Hi
We wouldn't advise anything apart from cleaning the chassis, as a build up of dirt and debris on the chassis would cause friction and make it difficult when trying to fold. Clean with furniture polish or dry Teflon spray and a soft cloth - don't use an oil based lubricant.
Other than that we'd recommend you contact the customer care team at crelations@djgusa.com for assistance.
Jun 21, 2012 | Quinny Buzz 3 Travel System Baby Stroller...
When I engage the deck to start cutting a loud noise begins and the tractor does not work. I previously hit a tree root with it's blades engaged. Can you please help? Thanks Danny
Sounds to me like you bent a spindle. Turn the mower off and get under it and see if you can spin the blades. The blades whould spin and not be wobbly. If either one of the blades are wobbly then you'll need to replace the spindle.
Also check to make the blade belt hasn't come off or is not destroyed.
Aug 01, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I've got a bugaboo chameleon that has a bent chassis and need to have it fixed.
Bugaboo will replace the frame if you're the original owner and it's less then two years old. If not you can buy a new frame for around $400! You will get some of that back in a better resale value. The frame is made of aluminum extrusions riveted into plastic frame members it is possible to reshape the aluminum parts but with out internal reinforcing it will easily bend again. In the UK BuggyPitStop repair frames.
Apr 28, 2011 | Bugaboo Frog - Blue Stroller
Kenmore micrwave overheated. now won't work. is
There is a fuse inside the chassis that can be accessed by removing the 4 side screws and the 6 back screws on the chassis cover. First unplug the unit then remove the 6 screws securing the cover to the shassis. Once the screws are removed lift the rear of the cover about 10 to 15 degrees and pull to the rear. The chassis cover will then come off. NOTE: There is a large capacitor inside the chassis that will stil have a charge. Make sure to avoid it when reaching inside the unit. Follow the power cord from where it enters the chassis to the end terminals. One of them will terminate at the fuse holder. Remove the fuse, obtain a new fuse of equal value amd intall same. Plug the unit in to see if you get some from of power be it a light inside or the contral panel lighting up. If it is just the fuse and you see signs of the unit having power once again unplug the unit and re-install the chassis cover.. Make sure that the cover interlocks on the front of the chassis properly. All mating surfaces should appear flush. Re-install the 6 screws and retun the unit to service. If nothing happens please reply to this post.
Jan 05, 2010 | Kenmore Microwave Ovens
How to replace lamp ballast 46hm84
Assuming you can get the part, here is the procedure to replace the lamp ballast:
1. Make sure TV is un-plugged and the lamp has cooled for at least one hour before continuing.
2. Place the TV on a flat surface with sufficient space to the rear to allow you to slide out the chassis.
3. Open and remove the lamp access door on the left-side of the TV (facing the front) by loosening the thumb screw. Behind the door you will find the lamp assembly which must be removed by loosening two screws (one on either side of the lamp base). Pull out lamp unit, careful not to touch the lamp or bump the unit. Set aside.
4. There are 13 screws that hold the lower-rear cover onto the cabinet. Use a 1/4 inch nut driver to remove these screws. Nine of them are along the top and bottom at the rear and another 4 on the left and right hand ends of the cabinet just to the rear of the front panel.
5. Next, note that the chassis is in two sections; left and right. The lamp ballast is part of the light engine assembly that is on the right chassis. You will save yourself much grief if you slide out both left and right chassis assemblies. There are 4 screws through the jack panel that hold the left-side chassis to the cabinet. Remove these screws. Also, there are two screws mounted vertically (one on either side) of the jack panel that hold the left-side chassis to the bottom of the cabinet. Remove these screws as well. Note that they are different from the other screws.
6. The right side of the chassis is held by 5 screws. First, remove the three screws that are holding the verticle metal brace and remove the brace. Note that there is a cable tie connected to this brace. Be careful not to cut or exert too much pressure on this cable tie or the cable running through it. Next, remove the remaining metal screws holding the right chassis.
7. At the top of the open cabinet just behind the metal brace that has need removed, you will see another metal screw that holds a light shield in place. This shield has several small wires that run through guides. Carefully remove these small wires from the guides remove the screw and gently remove the shield taking note how the shield is supported so you can re-install it again easily.
8. At the left side of the jack panel towards the front of the cabinet, you will notice some wire guides with wires routed through them. Carefully remove these wires from the guides so you can pull out the chassis without putting strain on the wires.
9. CAREFULLY, start to slide out both chassis sections, left and right. Be careful not to pull any wires. If you notice a wire that is becoming tight, stop and make sure you take the strain of off the wire before continuing. You will most likely not be able to fully remove both chassis. You will not have to in order to replace the ballast.
10. The ballast assembly is located in the right-rear portion of the light engine assembly. It is held on to the circuit board by four plastic posts and retaining clips, one on each corner. The projection lens is part of the light engine assembly and is exposed. DO NOT TOUCH the lens with your fingers or tools. Before you remove the ballast, you must remove a metal piece that covers the heat sink. There is one screw on each side of this cover. The one on the left is difficult to reach with your fingers so use a magnetic screwdriver if you have one. If not, use some kind of sticky substance on the point of the screw driver so the screw will lift up with it. Remove the metal cover. Next, remove the two screws that hold the brown lamp socket to it's base and carefully remove the lamp socket. Also, there is a small white cable connector on the right-rear section of the ballast that needs to be CAREFULLY removed. Do not pull by the wires; use a needle-nosed pliers to grasp the plug and gently wiggle if off the connector. Gently move the white plastic clips at each corner and lift off the ballast assembly.
11. When installing the replacement ballast, be careful to gently seat the ballast by exerting pressure only on the four corners where the posts are. In this way you won't crack the circuit board. Replace that small cable connector, the lamp socket (it's key-wayed so it cannot be installed wrong), and the metal cover over the heat sink.
12. Take you time and follow your steps in reverse order. The both sides of the chassis must be slid into the cabinet together to avoid too much tension on small wires. Notice that there is a verticle tab on the light engine chassis that must be aligned on the right side of a veticle guide that comes down from the top of the cabinet enclosure. If you do not have the tab on the right side, the chassis will not fully seat back into the cabinet. Replace the light shield, route the small wires through the guides and also those on the left side of the jack panel, replace all screws and braces.
13. Replace the lamp assembly and replace the lamp door and hand-tighten the thumb screw. The set should fire up. If it does not, the problem may be with the light engine in which case it will not be worth the expense to fix.
Good luck and take your time.
Jun 08, 2009 | Toshiba Televison & Video
My Bugaboo Chameleon bent
The best advice that I can give is to contat Bugaboo (www.bugaboo.com) who will be able to advise on the cost of a replacement chassis. Alternatively, you can purchase these from eBay most of the time.
I hoep this helps.
Apr 14, 2009 | Bugaboo Frog Stroller
Bugaboo Cameleon Jogger Logo
151 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
