Question about U-Line Icemaker
Water doesn't shut off in ice making tray - U-Line Icemaker
    Sergeant:
    Champion:
  • 351 Answers
Could be a bad water valve or the ice maker in side is stuck
Posted on Sep 29, 2010
Whirlpool mod#ED5FHEXNB00 isn't making ice
Freezer temp has to be below 10 degrees for ice maker to work. Also check to see if water/ice is in the tray. If no ice in tray then the water solenoid valve is not feeding the unit. If ice in tray then the heater is not working to melt the ice a bit so it can be scooped out into the ice tray. And make sure the feeler arm is down into the ice tray bin - if not, ice maker is shut off.
Oct 05, 2015 | Whirlpool Refrigerators
Pim10bls
Possibly the water control valve is leaking when shut off, and water constantly drips into the ice tray fill tube. When this happens, the fill tube becomes clogged with ice, and the ice tray does not fill. The ice tray will cycle often, because there is no water in the tray, but will remain empty. If this is the case, the water control valve at the bottom rear of the refrigerator will have to be replaced.
Jul 31, 2014 | Polar PIM10BLS Portable Ice Maker
Ice maker runs continuosly but no water is in the cube tray
It could be the valve. If it does not let water in, it will try to make ice and none forms so the motor keeps turning waiting for ice to form.
If the motor is turning its fine. Concentrate on how the water reaches the tray, its probably not getting there.
Dec 22, 2013 | Whirlpool Refrigerators
U line ice maker, the water doesn't shut off after filling the tray.
Change the water inlet valve if it is off and water continues to bypass the valve when off...Sea Breeze
U-Line Refrigerator Parts
Water Inlet Valve 2552A
Mar 25, 2013 | U-Line Icemaker
Water doesn't fill the ice maker trays
Most ice makers need to be at 8 to 13 degrees to make ice. If you had to defrost coil, then it's a defrost issue. Could be timer, bi-metal our heater.
Aug 17, 2012 | Refrigerators
Kitchenaid superba the ice maker not filling up and making ice
dear owittione perhaps the tray if its plastic maybe its cracked and the water drains out while filling check to see if there is a clump of ice in the bin and if so replace the ice tray no if is metal maybe the same thing is happening also check for the clump of ice in the bin. Now if you dont hear any water going in the ice tray maybe the magnetic valve in the back of the fridge is bunded out or the hose from the tap to the valves has a leak or the hose from the valve to the ice tray has a leak . Check around for water puddles if formed. Those are the probable causes that can lead to your problem ofcourse if the refrigerator over all is working fine. good luck. Regards Tony.
Dec 02, 2011 | KitchenAid Superba Architect KSCS25INSS...
Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice. Someone said it has a temp sensor and must be 10 deg b4 making...
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
Nov 02, 2009 | Whirlpool GS6NBEXR Side by Side...
FRS24ZGE is not making ice had a water leak a while ago so the water was shut off fixed leak and it is not making ice rod for ice tray has been done for a while when the water was shut off door has...
Hi Jeff, Had same problem. Turned out that the fill tube for the ice cube tray had filled with ice. I solved the problem by removing the tube from the back and letting warm water thaw the ice. Reinstalled and it works fine. You may also want to try a blow dryer while still in the freezer, but that may take some time. Good luck, Jim
Jul 28, 2009 | Frigidaire Freezers
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
U-Line Icemaker Logo
22 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
