Question about True T-49 Side by Side Refrigerator Commercial
T-49 sise by side door repair
I have two long rods to repair the doors how do I go about it?
  • 51 Answers
I assume you are referring to the cams in which the doors ride upon. The doors can be removed by lifting them up and off the cams. Once you have the doors off you can pull the cams out with a pair of pliers. After that proceed in reverse order of the above description.
Posted on Feb 20, 2009
How do I repair the door spring?
I believe you need to buy and install new door hinges.
Apr 21, 2015 | True T-49 Side by Side Refrigerator...
Seperating Gaskets
Call True in St. Louis and get a name of a supplier that carries factory parts. After market just doesn't work as well as you've noticed. Hope this helps and good luck.
Apr 07, 2014 | True T-49 Side by Side Refrigerator...
WANT TO REPAIR DOOR HANDLE DRIVER SIDE , ROD CAME OFF FROM INSIDE DOOR, CANNOT OPEN DOOR FROM THE OUTSIDE, HOW DO I RECONNECT THE ROD?
take the door skin off of the inside of the door. and you will see holes on the inside of the door if you look inside thes holes behind the door skin than you will find you rod in the latch mechanism is either off one side or both. what you then do is find the place the rod is missing from on the inside of the door somewhere and reconnect your rod and pop your door skin back on and you should be good to go.
Jan 10, 2010 | 1991 Dodge Dakota
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirpool sise by side rrfrigerator leaks d\from
there should be two small holes on each side of the dispensor cover
push a small nail in to those holes and pull forward
it will snap back in when your donr
Oct 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a ge profile side by side refrigerator.
First thing...Take a good look at all the door seals. If they let air and a lot of moisture in, that can condense and freeze causing your problem.
Second...Manualy defrost your freezer and see if the problem re-occurs. It may be that someone left the door open once and caused the icing.
Jul 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Car in minor frontal repair. Removed door handle LF Door, refitted, now door won't open
it sounds like the door lock mechanism that the door button rod connects to inside the door is in the locked position.
Has the rod for the door handle been connected to the lock mechanism?
May 12, 2009 | 2004 Volkswagen Golf
RE: true T-49
check the hinge position it's probably off line
Jul 22, 2008 | True T-49 Side by Side Refrigerator...
True T-49 Side by Side Refrigerator Commercial Logo
156 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
