Question about Apple iTunes
MY I 4 GOT THE CODE AND NOW IT SAYS IPOD IS DISABLED CONNECT TO ITUNES AND I HAVE A NEW COMPUTER SOOO WAT DO I DO CAUSE I CANT PLUG IT IN TO THE SAME COMPUTER I DID IT WITH CAUSE I DONT HAVE IT I NEED MAJOR HELP PLZZ HELP MEH I AM BEGING YA
    President:
  • 2,291 Answers
1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Posted on Sep 29, 2010
Password forgotten now say's disabled
Unlock a Disabled iPod
If you own an iPod Classic or iPod Nano, you can set a four-digit security code on your device and then lock it to keep other people from accessing it.
Disabling your iPod is a good way to protect the data on your device, but if you lose or forget the four-digit code, you will need to manually unlock it in order to access your music and other content.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
Or
Hard Reset a Disabled iPod Touch
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
http://support.apple.com/kb/HT1808iOS: Unable to update or restore
Jul 30, 2013 | Apple iPod touch
I have an 8 gb ipod touch that is now disabled because I can't remember the 4 digit code. The message on the ipod's screen says 'ipod is disabled. Connect to itunes.' The computer that I originally used...
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
May 20, 2010 | Apple iPod touch
Ipod is disabled connect to itunes
Go on to itunes and plug your mp3 in to your computer
and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
Double Problems...
this problem happens when you try connecting a ipod to a new Itunes. If you know the lock code you can remove it temporarily until you have it connected and authorized for that computer then you can apply a lock code to it again. the lock code can be removed by going to the settings icon then general option and turning off the passcode lock. then plug into your computer and Itunes will start and go and authorize that computer then all should be good.
Aug 05, 2009 | Apple iPod touch
My ipod touch is disabled and i cant hook it up to itunes cause it needs a code but its disabled and is stuck at the disabled screen.
you will need to put your touch into recovery mode aka DFU mode.
Here are the steps:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Iphone and itouch dfu mode
Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
Jun 16, 2009 | Apple iPod touch
Ipod touch says its disabled
Use the cable included with your iPod touch to connect the device with your computer. Plug the fat end into your iPod touch and the longer end into your computer.
Jun 06, 2009 | Apple iPod touch
Itunes cant restore it wat do i do ?
you will need to put the phone in DFU mode.
here is the steps.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
if you have a version of iphone firmware you want to restore to on your computer already, when you hit the restore button in itunes, press SHIFT on your keyboard and it will let you choose a file.
if you have any further questions let me know
Good Luck
Jun 02, 2009 | Apple iPhone (16 GB) Smartphone
8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
if you need any further help let me know.
Good Luck
Jun 01, 2009 | Apple iPod touch
I dont know what to do please help me my ipod touch is disabled.
press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
Feb 02, 2009 | Apple iPod touch
Ipod classic 80 GB wouldnt allow me to load music.. now it wont appear in itunes either
My classic won't sync at all. When I plug it into a USB port a screen comes up on my ipod saying "connected" then within seconds it's replaced by another screen that says "ejecting"
It works fine on my son's PC and my wifes Mac. Just not on mine. I have disabled the firewall. Tried all the various USB ports. I know cable is fine cause it works on other computers. I have latest in ITunes and have service pak 2 with XP. So needless to say I have tried everything I can think of to resolve this. HELP!!!!
Nov 02, 2007 | Audio Players & Recorders
Apple iTunes Logo
47 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
