Juster speakers 3D-503 no sound
I used to have sound on my computer then i had to reboot my computer with windows xp home edition and now i havent any sound at all
  • 103 Answers
the problem is that since u cleared off your hard drive you lost the drivers for the audio card so its not the speakers. you have to go to your computers manufacturer's website and go to help and support and get the driver for your system model's audio card if you tell me the model of your computer i will locste the driver for you and get you the direct link.
please rate me. thank you.
Posted on May 24, 2008
I'm running Windows 8. Do I need a driver for my Juster SP-660 Speakers?
Unless you already hear something from the speakers when you hooked them up, the answer is yes.
Mar 04, 2015 | Juster Multimedia Computer Speaker System...
No sound in my juster 3D-108 superwoofer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 25, 2011 | Juster 3D-108 Computer Speakers
Need to find drivers for Juster SP-221 speakers (Windows XP). Thank you!
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope one of these helps
May 23, 2011 | Juster SP-225 Computer Speakers
I need a driver for my Juster 3d-101 for windows 7 where or how can I get one?
why do you need a driver for your speakers? Have you no sound at all? Windows only needs drivers for the sound card not the speakers. Please explain what the problem is and make and model of sound card or computer
Apr 09, 2011 | Juster 3D-102 Computer Speakers
Since loading Windows XP, speakers do not work. Do I need a new driver? Where from?
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 05, 2010 | Juster SP-691N Computer Speakers
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
XP with no sound
Ok go here http://www.emachine-upgraders.info/d...ownloads.shtml
install the Intel INF Patch 4, then RESTART your comp, you have the Realtek driver install again
DON'T FORGET THE SYSTEM RESTORE POINT BEFORE INSTALLING EACH DRIVER
P.S.: If this information was helpful, please rate this solution.
Mar 13, 2009 | Microsoft Windows XP Home Edition for PC
No sound
go to HELP & SUPPORT , and follow the steps there , it have a diagnostic check procedure and will instruct you what to do to re connect the sound , you will see the speaker icon at the toolbar , this means is active, hope this helps
May 06, 2008 | Microsoft Windows XP Home Edition
I NEED HELP
Please post the make / model number, and I will be glad to link you to the site to obtain the sound driver.
Jan 09, 2008 | Juster Computer Speakers
127 people viewed this question
 Grubhead
Grubhead
