Question about Fisher and Paykel Dryers
We have a Fisher & Paykel AD55 manual dryer. Today, it didn't spin however you still can feel the heat turned on when you turn on the dryer. We have been doing trouble shooting following the manual (door lock, power plug, filter, etc), it still doesn't work. Anybody can help us? Thanks a lot!
4 Suggested Answers
  • 2468 Answers
SOURCE: I have a Fisher and Paykel AD55 dryer. When I turn
if it tries to start when you push the start button and quits when you release it,the belt is broken,theres a belt sensing switch by the motor so when the belt breaks the unit wont stay running
Posted on Oct 02, 2010
sonicboomele
  • 1557 Answers
SOURCE: how do I replace the main bearing in an AD55
not that hard you take the back of then take the barrel out punch out the 56833 strem grease bearing then replace with new one and re assemble just note the way the driver belt comes of there tricky to put back on
let me know how you went
Posted on Dec 31, 2010
  • 3074 Answers
SOURCE: How do take my fisher
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Posted on Apr 15, 2011
Fisher & Paykel gas dryer tub turns but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 15, 2011 | Fisher and Paykel DG05 Gas Dryer
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Old fisher and paykel dryer AD55 doesnt always heat up.
there's a heat senor on the back of the drum(I think) most of the older model dryers have them check to see if it's bad
Mar 31, 2011 | Fisher and Paykel DEGX1 Electric Dryer
How do I replace the main bearing in an AD55 Fisher & Paykel dryer? How difficult is it to get at?
Dec 31, 2010 | Fisher and Paykel Dryers
F&P AD55 manual dryer - With very light load motor make noise but will not turn. If I open door to spin drum and quickly close door it sometimes will start turning. Help!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 21, 2010 | Fisher and Paykel Dryers
I have a AD55 Dryer. When I turn it on it makes a sound but the dryer doesn't turn around.
Does the sound it makes sound like a motor running? When you start a dryer a motor that is coupled to the drum starts turning. It is possible that the belt has come off of the motor pulley. You will need to remove the back cover and look inside to determine if this has happened.
Oct 02, 2010 | Fisher and Paykel Dryers
AD55 Dryer makes a dual clunk like it is out of round.
Run the dryer and look through the front door and watch for if the drum is running out of round at the back. The AD55 only has one bearing and this is at the rear of the drum, the front of the drum is supported by 6 plastic tabs that it glides over. These tabs are reversible if they become worn and a drum bearing assembly kit is available from Fisher & Paykel. For a detailed drawing of the dryer contact your Fisher & Paykel service center and they will email you a copy.
Mar 02, 2010 | Fisher and Paykel Dryers
Fisher Paykel Elec. Dryer
Usually the belt is a single piece that wraps around the entire drum. The fact that you smelled something and that you feel the clothes are not being tossed tells me that the belt was slipping on the pulley of the motor that drives the drum. This will heat up the belt causing the smell. If the belt gets too loose, this will happen. I'd replace the belt, and I think you'll be back in action.
Let me know what happens. Please rate accordingly.
Sep 18, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Open Questions:
Dryers Logo
64 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
