Question about Garden
Where can I get repair parts for a 5 hp Bufflo air compressor? Model AC5HPV
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
  • 583 Answers
SOURCE: Need help with parts for air compressor.
Hi ,Crazy horse. information perfect . with a14.5 inch pully on the compressor and amotor running at 3450 rpm you can get with a 5 inch pully----1189.6 revs per min ---- with a 4 1/2 pully ---1071..6 revs per min so you hve to decide whether you want the max or the min from that compressor... If it was for me I would use the 5in . and set psi. with the cut in ---cut out switch ,this will be a good unit ,,if you need any more help don`t hesitate to call and thanks for the opportunityto help it is great when some one gives you good info .you did well
Posted on Aug 12, 2009
Testimonial: "Thank you so much! I had searched every where and no one could answer that question. I feel comfortable now! Job WELL done!"
ollie reece
  • 1167 Answers
SOURCE: i have sears craftsman 22gal 5 hp air compressor not enough press
hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Posted on Oct 05, 2009
Testimonial: "thanks i took out the check valve i see the rubber but the valve is 1 piece should i just get a new one"
  • 672 Answers
SOURCE: I have a Sears 3 H.P. electric 30 gal air compressor
This link will take you to sears web site, where parts are available. I have linked you to the parts list. If this does not take you there, go to www.sears.com and click on the parts direct tab and enter your model number.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=106.154880&productCategoryId=0703000&brandId=0247&modelName=CRAFTSMAN-TWIN-CYLINDER-TANK-TYPE-PAINT-SPRAYER&diagramPageId=00001&documentId=00001361&pop=flush
Posted on Oct 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Posted on Dec 24, 2009
Hi, I have a DeVilbiss air compressor Model No. IRL 5020 5 HP 20 gal reservoir twin cylinder and would like to obtain a service manual. Thanks Gerry
you can try their website . many companies do not sell or give service manuals out except to their repair site people . it is called JOB SeCURITY
Jul 16, 2016 | DeVilbiss Air Tools & Compressors
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    Supply tub to tank
    That is really not a hard part to find. You should be able to remove the broken one and take the whole tube into a hardware store and they can replace it for you. It should be a copper tubing with flare nuts on the ends. If not please post the model number of the compressor
    Apr 27, 2013 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
    I have an old IR 30 T that needs repair where do I find a manual for this
    You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
    Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
    Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
    Husky Manual for TF291201AJ
    Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
    Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    I need to replace the belt on my 5 HP 120 volt 27 gal tank Model WL660001AJ Air compressor. I don't know the part number on the belt, or where to purchase. Can you help?
    Hi, my name is John. Welcome to FixYa. Take the belt with you to most any auto parts store and they will match one up for you. Thanks for choosing FixYa...John
    Nov 19, 2010 | Campbell Hausfeld 26 - Gallon Air...
    Can't find Ring's for my Sears air compressor, model 106.154540
    Try a small engine repair shop, or even a industrail compressor repair shop.
    Also look here for parts good luck
    http://www.about-air-compressors.com/needs-some-replacement-parts.html
    Sep 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Garden Logo
    60 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
