Question about BlueStar RNB48 (Gas) Kitchen Range
My bluestar rnb48 continually sparks even after the flame lights. What are the likely problems and solutions.
    Problem Solver:
  • 8 Answers
Bluestar uses a cheap china made spark control unit. chances 80% that it needs to be replaced. contact bluestar direct for this part and they will ship it to you so you can have a local tech change it out for you.
Posted on Feb 15, 2015
  • BlueStar Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Posted on Sep 29, 2010
One burner won't spark when another is aflame. Multi-ignition BlueStar 4-burner range.
I would check that the plates are on correctly. Make sure they are aligned and sitting properly. Sometimes they move while cleaning and give you a bad ground connection for the spark.
Feb 15, 2016 | Kitchen Ranges
I need schematic for model RPB304BSS
PDF]parts identification for the bluestar line of - Guaranteed Parts
www.guaranteedparts.com/.../Parts%20identification%20for%20Ranges...
RGTNB36, RNB48, RGTNB48, RNB60, ALL HERITAGE CLASSIC MODELS,. SALAMANDER. Parts Manual. Freestanding Gas Range/Cooktops. 600 Arlington ..
Sep 19, 2015 | Kitchen Ranges
Blue star propane to natural gas
http://bluestar-store.mwrc.net/en/product.php?product_id=40188
That is the kit you need. Usually comes with step-by-step instructions on replacing the orifices, converting appliance regulator, setting damper, etc...
Jan 20, 2014 | BlueStar RNB48 (Gas) Kitchen Range
BlueStar RCS 6 burner range - brand new - ALL 6 burner ignitors spark when I turn on ONE burner. I came across some BlueStar literature that suggested this would be a problem. A representative from...
The units that are ending in BSS have multi ignition like you describe and the units ending in BV1 have single ignition.
BSS = All ignite
BV1 = single ignition
Nov 10, 2010 | BlueStar RNB36 (Gas) Kitchen Range
No spark and no power: Bluestar 36
Is there power at the outlet? I know that it is probably very hard to get to behind the heavy Bluestar, but it looks like you may have to pull the stove away from the wall and make sure it is still plugged into a working outlet. All of those stove functions are fairly separate, so to have all of them go out, you probably have a power supply problem. There may even be a break somewhere between the plug and where it splits off into the fan/light/ignitor parts.
Dec 08, 2009 | BlueStar RNB36 (Gas) Kitchen Range
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
The electric spark lights the gas at the spark area but the rest of the oven flame never materializes and the spark continues to click even though the initial flame is there
Make sure the thermocouple from the gas valve is in the pilot flame. If it is and you have no ignition,replace the gas valve. The clicking stops once the oven ignites.
Aug 24, 2009 | Roper FGP215KQ Gas Kitchen Range
Igniter wont stop firing
Make sure that the small burner holes near the ignitor are not clogged. if no flame is visibly touching the ignitor, then the ignitor will not sense that it is lit. The fact that it seems to take longer to light than normal leads me to this as well.
If there is good flame contact with the ignitor, then sometimes it will not sense the flame if you had a boilover and water got down between the wire and the ceramic body. This can happen with oil as well. Removing the ignitor (carefully! if you crack it, it will "leak" its spark and not work properly), cleaning it and letting it thoroughly dry will help. Most of the time I just leave the burner on and the clicking will stop after about a minute when the whole assembly heats up and drys out.
If all that checks out, then the ignition module is bad. Mine went out after 6 years use. They are available online (I bought mine from a Viking parts store...surprisingly). Replacement is fairly easy. Turn off the power to the stove. Remove the screws that hold the burner knob/oven knob faceplate to the range (Two are only accessed by opening the oven door, the rest are tucked up at the top of the faceplate and under the top-front lip of the range) The ignition module has many wires attached and they are easy to remove. MAKE SURE YOU ATTATCH THE WIRES TO THE NEW MODULE IN EXACTLY THE SAME SPOTS ON THE NEW IGNITOR. That includes the same ignitor wires that are all colored the same.
I absolutely love my Bluestar. I wish my convection fan was quieter, but the power of the range is simply awesome.
Apr 23, 2009 | BlueStar RNB36 (Gas) Kitchen Range
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Viking Stove electronic ignition keeps sparking
Why suddenly my ignition are not spark and did not light the flame on two burners?
Dec 26, 2008 | Kitchen Ranges
BlueStar RNB48 (Gas) Kitchen Range Logo
453 people viewed this question
Top BlueStar Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a BlueStar Kitchen Range Expert? Answer questions, earn points and help others
