Question about Garden
I have severl holes in my back yard which i assume are from old tree root systems. They are about 6'-10" in diameter. I have filled them with fill dirt or sand several times yet the material continues to settle. Is this the best way to get them filled or is there a quicker solution? Or should I be concerned about an animal digging them back out? I don't think it's an animal since there's no material left outside the hole, so i am pretty sure it is settling.
  • Rick Sep 29, 2010
    Thanks for the quick response!
  • 2,299 Answers
You could have a sinkhole. I don't know what part of the country that you are in, but my little brother is in a lawsuit because a Realtor sold him a house that they knew was on a sinkhole. And his yard is doing the same as you described. You can take a bag of Sack Create and fill the holes partially and then put fill dirt on top of the concrete after it hardens. This will give it a base so it won't settle anymore.
Posted on Sep 29, 2010
How do I remedy a root bound mini orange tree
If the larger pot has sufficient space for the roots you shouldn't need to trim them but using your fingers to carefully loosen them would be helpful. If you do have to trim the roots do it carefully. Be careful not to shock the tree by moving it to a different location or letting it dry out until the root system has had time to re-establish in the new pot.
Nov 10, 2014 | Cooking
Tip
Cheap coolant overflow cap
Contaminated coolant contributes to engine damage by clogging up the radiator, reducing efficiency of the coolant to remove engine heat. an uncapped overflow tank is a route for debris and contaminents to enter your cooling system and if ignored, circulate crud thoughout the system and clog your radiator. So if you have lost your coolant cap,(which is easy to do) dont just say "oh, well" there is a temporary fix that will keep your coolant clean until you can get to an auto parts store and replace your cap with the proper cap. all you will need is a plastic bottle, or container cap and some electric tape, or, yes, even duct tape. eyeball the approximate inside diameter of the radiator overflow tank fill hole. place the bottle cap over the fill hole, but dont let go of the cap. if the cap is smaller than the hole wrap electrical, or duct tape around the cap a few times and replace bottle cap over the fill hole. the cap should fit snug in the fill hole. make sure you dont press cap into the fill hole too deep that you cant pull it out with your fingers. if you do you can pull it out with needle nose pliers. this will keep your coolant clean until you can get to an auto parts store and replace the cap with a proper cap.
on Dec 28, 2010 | Dodge Ram 1500 Cars & Trucks
I have a large locust tree growing close to the foundation of a building and adjacent blacktop sidewalk in the community where I live. My concern is the damage the root system may cause to the buildi
Locust Trees (like many other varieties ) have root systems that easy reach out as far as the foliage and beyond, especially in ares were root growth may be obstructed by buildings or soil may be poor or the tree lacks proper water. A contractor said to me once about such an issue ... "If the tree lives, the roots always win." Many varieties of locust have shallow rooting systems and eventually will lift sidewalks or crack cement.25167623-m2gmjme2lggf3syeo4u4b11f-1-0.jpg
A solid poured concrete foundation may withstand the pressure of the roots for an extended period of time, especially if it is thick and strong. Block concrete offers less resistance.
Most contractors and landscapers will suggest you plan to take the tree out in the near future
Oct 01, 2014 | Garden
Overheating at highway speed
old post got air pockets in it, burp it like we do all cars.
ask
see list of 17 signs here, (evidence)
http://www.fixkick.com/overheating.html
and all cures.
just for G16 engines
both 8v and 16valve versions.
i bet its cold out.right? February.
Cel lamp out running, if not, spark timingen may be way wrong.
when the read tubes clog then spark is wrong, the rad can overheats due to 2 failures at once. ? even 3.
or cap is no good, or thermostat bad.
you have tons of cold air there moving so the rad would have to be super clogged to fail
thermostats are weak technogly, see netfilx video of tour o that.
and he show why, they go bad 3 to 5 years old.
shorted lived part. so we always assume that it bad.
like car batteries, same deal ,weak tech.
or not burped right
proof?
easy
  1. pump in, all in.
  2. fill it with 50% AF ,right, to top of neck ,side tank 1/2 full.
  3. run (idle) engine until AF exits filler cap hole, kill engin, put on new cap.
  4. drive around block
  5. let cool below 130F or near.
  6. open cap.
  7. is it still full, sure its not, its got air pockets, all do.
  8. fill again, jump to 4.
g16 are not hard to fill
unless shade tree puts therm stat in, with bleed hole forward ,up hill. or upside down.
Feb 18, 2014 | 1992 Geo Tracker
Can i cut my yucca trees down and plant them elswhere in the back yard
Yes you can, just don't pull them out of the ground, dig around them and deep enough to keep most of the roots intact. Dig the holes where you want to replant them first before digging the yuccas out!!! Once you have your plant dug out replant it in the new hole as soon as possible, use some good potting soil to fill around it and water it.. Yuccas are very tough plants so you should be OK.
Nov 13, 2013 | Color Guard Yucca - Yucca filamentosa...
How do you use roundup to kill a tree stump?
Hello, I am a grower and licensed pesticides applicator (40 yrs exp).
Roundup lost the trade mark years ago,"glyphosphate" which is now marketed (cheaper) under many other names,
Will kill a live tree if sprayed on the leaves! Also will damage young trees if you just get over spray on the trunk while spraying weeds.
Also, kills grass as well as broadleaved plants.
To kill a tree you would need to spray the leaves, then wait at least a month before cutting the tree down. I have successfully killed a few stumps by spraying the live suckers.
Be especially careful of spray drift as the finer the droplets are the more effective the chemical is. Read the label!
Aug 29, 2010 | Roundup "" Weed & Grass Killer
I have a trench 1475' long, with three rows of 3'' pipe.
If the pipes are 3" outside diameter, the displacement is 24.15 cubic yards, however standard 3" pipe is 3.5" diameter, which would displace 32.85 cubic yards. 505.32 cubic yards is correct for the total trench volume.
Mar 23, 2010 | Plumbing
Andrew is ordering the top soil to fill the planter. topsoil is delivered by the cubic yard, and cost $43.00 per cubic yard, tax and delivery included. the determine the cost for the planter.
How big is the planter, what are its demensions. Figure out how many yards in the planter, Right? Either full yards or partial. Or you can buy the top soil in bags, start filling the planter, and when you over fill and spill on the ground you have the right amount, Also you must ask are there plants in the planter, because they will take up some room with their roots.. Good luck...By the wayis this a left handed planter or a right handed planter, ????
Apr 13, 2009 | Office Equipment & Supplies
New American Standard Flowise toilet won't flush
You have a sewer issue....it is entirely possible for other things to cause the toilet to loose water as they drain....but only if there is a sewer problem.....that is why there is an air gap between the toilet and the tank...(the trap) now I have been in this industry 35 years and the jet you speak of is in the bottom of the toilet that directs and forces flow down and out of the bowl as do the many small holes on the underside of the bowl lip ( I suspect ...as I have seen it MANY MANY time in the paste) that your old bowl may have had lots of calcium or lime build up (using lime a away occasionally helps) in the holes under the lip as well as other places...which reduces water flow and there by reduces pressure......but what you are describing is definitely sewer related....other water sources causing water to drain...bubbles...etc..I had a similar problem that occurred about once every 2 years in one of my homes...I had a tree root growing into my sewer line ...it would flush but on occasion...debris would get caught and a good plunging would help...but eventually...(twice) I had to rent a 3/4 inch snake from Time Rental...with a cutter head on it and remove the problem. Now your problem sounds exactly like an air gap problem...in that an overflow or something related is causing a vacuum assist when large amounts of water are drained...(ie...tub...washer...).as this happens the force the water carries and the lack of access to air in the flow causes vacuum "tugs" on other water sources attached to the sewer....take of your clean-out cover (usually in the back of the house and if you see water standing in it ....sewer problem....also you can have someone flush the toilet and eyeball the sewer/overflow...to see how it drains.
I hope this helps....good luck...thank you for rating my effort...the Fang.
Mar 27, 2009 | American Standard Colony 2388.012.222...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
