Question about Philips AJ3980 Clock Radio
Philips Aj3980 I used some glass cleaner to clean the screen and some of the fluid seeped into the bottom edge of the screen. There must be an electronic panel where the fluid has touched and now I can't get the radio to change channels. Any ideas please? How do I remove the casing to get to the panel to see if I can clean it up?
Have the same problem as i used it in the bathroom where it got damp. about to open it up an have a look, probably just need to dry it out and remove any cleaning residue. you should not use any kind of fluid on the screen, to clean it a barley damp cloth maybe?
Posted on Sep 06, 2008
What are the approved cleaning fluids for use on the underside of the object glass?
  • Use any fluid approved for use on glasses or camera lenses. Glasses and photo lenses have coatings that should not be subjected to be acidic cleaners. Windex, for example should never be used on car window tint... who knew?!?
Feb 27, 2015 | Office Equipment & Supplies
I did something wrong.....
Windex is not the best cleaner. Bed and Bath Beyond has a very good NON-Streak class cleaner that I tell my customers to use. The best solution is NOT to Spray directly onto the TV Screen. Remember the glass is only delivering the picture from an RGB projection unit sitting inside the enclosure. It is not the electronic projector and the screen is separate. It can be replaced if damaged; however I believe it is only streaked and needs proper cleansing. If you get the new cleaner, spray the solution onto a soft cloth and wipe the exterior screen. Promptly wipe it dry and if you need to do this a few times, eventually you will get the glass clear and enjoy the show.
Dec 18, 2013 | Panasonic Televison & Video
I cleaned my projection panasonic magnavox tv with windex, not there are streaks coming up from the bottom of the screen followed by black spots, did i damage it completely, should i turn it off, and let...
Never spray directly on a screen. If the solution seeps into the underside (back etched side of the glass) it could damage the surface. You may have to get to the inside from the rear projection area or lift of the front glass screen and remove it completely. Usually the Rear surface of the screen is etched and can be wiped clean. Go to Bed Bath and get a good streak less windows cleaner. Spray it on a soft cloth and wipe the front and/or back glass. Wipe dry with a CLOTH, not a paper towel, and when dry use a flash light to see any streaks or blemishes left behind. Clean again is necessary. Do not apply pressure, gently clean and try not to cause scratches as they show up when the projection device flashes the image on the glass portion. Put it all back they way it was and enjoy.
Dec 18, 2013 | Philips 9P6040C 60" Rear Projection...
What is the best to use to clean fingerprints on the screen? Soap and water or glass cleaner?
I always suggest Monster Screen cleaner, It is not alcohol based and is designed for cleaning LCD screens. I use this professionally in my tv shop, this stuff is great, even removes crayon marks.
http://www.youtube.com/watch?v=523NZbh_Qpo check out this guys review.
Aug 03, 2011 | Philips 32PFL3505D 32 in LCD TV
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the...
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Jan 12, 2010 | Refrigerators
I have a pHILLIPS 46 INCH PROJECTON tv. tHERE SEEMs to be a blue arc of light on the bottom third of the tv. When there is white on the screen it reflects in blue.
If the convergence is OK in this area of the screen, msot likely there is a problem with the coolant fluid in the blue tube. Somtimes the fluid starts breaking down and gets cloudy or a bubble has developed in the fluid. Look down through the blue lens from the back while the set is playing and see if you can see the problem. Could also be something on the lens itself. Clean it with ammonia free glass cleaner. Thanks for using fixya.
Dec 26, 2009 | Philips 60PP9200D Television
How to clean the screen
Use a soft lint free cloth and any glass cleaner. The trick is to spray the cloth instead of the TV screen. Spraying the screen itself could let cleaner run too far down and on to the circuit board. Thanks for using fixya.
Dec 06, 2009 | Philips 27PT6441 27" TV
How do I take the front screen off to clean the bugs out? Philips 60PP9100D-37 60" Widescreen Projection TV
First: do not take front screen off for cleaning--easy way is to remove entire black plastic shroud (you look at back of set and you will see 2 silver pegs near top edge) This set uses torks type screws---you need to remove several and the entire upper plastic in back comes off. The mirror is suspended separate from this.With the shroud removed you can clean the lens of the 3 picture tubes or any debris on the inside of the screen----do not use glass cleaner on the screen; but if you have smudges or bugs on the inside just use a very fine soft cloth(you may need to moisten it slightly) Any mark you make will show! If you find you have spider webs use a swiffer type duster to remove them.
I do this here for free so if this was helpful give me a vote here. If you have questions or need help let me know.
Aug 03, 2009 | Philips 60PP9200D Television
How to clean 50 in rear projection tv
For the screen Philips make projection screen cleaner this is a spray with brush that is made for cleaning tv. The CRT's you can use some type of glass cleaner, not to waste on board.
Oct 05, 2007 | Philips 50P8341 50" Rear Projection...
Open Questions:
Philips AJ3980 Clock Radio Logo
175 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
