Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin making a humming noise - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 29, 2010
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Won't spin
Hello fopdycke - Typically when a washer does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage pump or hose may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, timer, faulty pump or control board not communicating correctly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 11, 2013 | Frigidaire ATF6000ES Front Load Washer
My washer won't spin
Hello Michael Johnson - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
Jan 04, 2013 | Frigidaire FAFS4272LW Washer
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Won't spin out and makes a humming noise
Wait for your handsome husband to come home and have him fix it. jk
Nov 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
I have a whirlpool washer and it will not spin
The problem will be in the main board or the spinning coil may be short circuited, You can easily check the motor during the spinning process you will find the humming noise if you do not found any humming noise kindly replace the board
Dec 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
