Question about Super Tutor Trigonometry (ESDTRIG) for PC
Two sides of a parallelogram are 694.50 feet and 418.32 feet respectively; one diagonal is 602.94 feet. what is the length of the other diagonal?
How much poster paper will be needed for a parallelogram-shaped banner with a height of 3 1/2 feet and base 6 1/4
if the roll is 3ft 6 inches wide you need to say the length of the roll ( 1 ,2 ,3 yards etc ) really you do not have enough information to get an answer
Mar 27, 2017 | Banner Office Equipment & Supplies
The diagonal of rhombus are 8 cm and 6 cm then the length of each side of the rhombus
https://www.mathsisfun.com/geometry/rhombus.html
Lesson HOW TO solve problems on the rhombus sides and ...
www.algebra.com > Geometry > Customizable Word Problem Solvers
  1. Cached
Lesson HOW TO solve problems on the rhombus sides and diagonals measures - Examples ... Find the perimeter of the rhombus, if its side is 7 cm long. ... Since all four sides of the rhombus have the same length, the measure of the side ... 32/4 cm = 8 cm. ... In our case the legs are 12/2 cm = 6 cm and 16/2 cm = 8 cm long.
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm ...
  1. Cached
  2. Similar
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm. What is the ... (paid link). Click here to see ALL problems on Geometry Word Problems ... We need to find the side of the rhombus using the Pythagorean Theorem. After that, we use ...
The diagonals of a rhombus are of lengths 6 cm and 8 cm. Find the ...
https://in.answers.yahoo.com/question/index?qid...
  1. Cached
  2. Similar
Jun 29, 2013 - The diagonals of a rhombus are of lengths 6 cm and 8 cm. ... rough aketch and you will see that in each triangle the shorter sides are 3 cm and 4 cm, so using the Theorem of Pythagoras, if we call the hypotenuse l cm, then l^2 ... Rhombus
Mar 30, 2016 | Office Equipment & Supplies
The three dimensions you have given are also the three sides of a triangle. the length of the other diagonal is equal to twice the distance from the center point of the 602.94 diagonal to the vertex between the 694.50 and 418.32 legs.
Do your homework.
Feb 02, 2015 | Computers & Internet
Perimeter of a parallelogram
If it's a parallelogram, the other two sides must be equal as well. You already know two of the sides as 13.6 each.
Your equation would be as follows (using x for the solution)
94 - (13.6 + 13.6) = 2x
Jun 22, 2014 | Computers & Internet
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
A rectangle is 87 feet by 136 feet. find the length of the diagonal and the angles that it makes with the sides.
Length of diagonal =SQRT(136^2+87^2)=161.4465856 ft
One angle = arctan(87/136)=32.60... degrees
Other angle= 90-32.60=57.39 degrees
Sep 10, 2011 | Super Tutor Trigonometry (ESDTRIG) for PC
What is the math definition for area?
Area - The size of a surface
Specific
Square
Area = Side x Side
Rectangle
Area = Length x Width
Triangle
Area = Base x Height (cut the answer in half and that is your area)
Parallelogram
Circle
Area = Radius x Radius x 3.14
Aug 30, 2011 | Computers & Internet
1.the ratio of the corresponding sides of two similar traingle is 3:2 what is the ratio of there height 2.the ratio of the corresponding sides of two similar traingle is 5:9 what is the ratio of...
1. the ratio of there height is 3:2
2. the ratio of areas of the triangle is: 125:6561
3. the perimeter of smaller parallelogram is: 40 cm2
4. THe real length of the object is 7 cm
Jan 21, 2011 | Dell Computers & Internet
How do you find the area of an irregular rectangle or parallelogram?
There is no such thing as an irregular rectangle. This being said, I believe that the area of a parallelogram is still equal to the product of the base by the height.
Draw your parallelogram with one side horizontal. From the next corner, draw a line perpendicular to the base. The length of the segment you just drew is h. If b is the length of the base the area is b*h.
Hope it helps.
Oct 08, 2009 | The Learning Company Achieve! Math &...
Computers & Internet Logo
100 people viewed this question
Top Super Tutor Computers & Internet Experts
ali_zulfikar
ali_zulfikar
ka4iup
ka4iup
Are you a Super Tutor Computer and Internet Expert? Answer questions, earn points and help others
