Domain Air Split system KFR-70GW/c will not start in either Warm or Cool mode. The External unit fan rotates but there is no compressor activity nor any internal fan operation. Can you please help me to fix this problem?
Nitrotrike
  • 589 Answers
SOURCE: Parts for split mini air conditioner external unit
You may be able to contact Soleus here:
http://www.soleusair.com/Contact/contact.htm
Posted on Jan 11, 2008
  • 441 Answers
SOURCE: Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Posted on Jul 17, 2009
shastalaker7
  • 1515 Answers
SOURCE: have a reverse cycle split system LG aircon
Hi, dealing with these ductless split systems on a daily basis, I can say you have checked some of the things I would have wanted you to check, which is good on you're part.Blowing Room Temp. air in both heating and cooling indicate that the compressor is not running even though the outdoor condenser fan is on.There are several things that could cause this. You have a compressor run capacitor that starts the compressor, but I am thinking on you're unit, it has a dual capacitor that runs the compressor and fan together. Fan is on, so I will rule this out.These units are notorious for leaking freon as the Liquid line and suction lines are not brazed, they are put together with connectors that tend to leak over time. If it is low enough on Refrigerant gas, the compressor will shut off and stay off on low pressure. This unit has a low pressure switch that has normally closed contacts, that opens and stops the compressor from any damage which in turn, you will have no cooling or heating.Do this for me, turn the unit on in cooling, lower T-stat way down so outdoor unit comes on. Go to the out door unit and where the elect. wiring and lines go into unit you will see to copper lines. The largest of the 2 lines is the low or suction line.Wrap you're hand around it and it should be nice and cold. If it is warm, just touch the smaller line, it should be rather warmer, almost hot.If both lines are of normal temp. you are either out of freon or the compressor isn't running.You can remove panel to get to it and put your hand on it to see if it is on. If the lines were of normal temp. and the compressor is not on, more than likely you have lost the charge.Look it over, the wiring to see if you see anything burned or connections burned off and so on. You can check the 3 wires going into the compressor by turning off the power at breaker and removing the cap covering wires just to make sure these wires are intact. sometimes one will get hot from power and burn off. If you see this problem, it would be something you could fix.If all looks good, go back to the copper lines and being this is a Heat-Pump, you should have 3 fittings where we install our gauges to check and fill systems with freon. Look for one that is on the unit itself and remove the plastic cap.Don't be alarmed if you do as nothing will come out.If you look inside the valve, and you see a Schrader core, you can depress it with a nail or something small, just enough to see if it has a lot of pressure in it.If very little or none, the system is out of freon. You will have to call a tech out to find leak and evacuate and re-charge system.I wanted to give you many things to check so you and I would know what the problem is, a process of elimination. If you have a lot of pressure, then more then likely you have a faulty compressor. If you feel that you would rather not check the electrical or depress the Schrader, I fully understand.You can at least check the temp. of the lines and listen to see if the compressor is running, and if it is with warm lines it is still low on freon.Please keep me informed, and again the long explanation was for you to understand more about you're system operation. Sincerely, and best of luck,
Shastalaker7
Posted on Nov 23, 2009
SOURCE: Amani Whisper Series Model KFR 70GW keeps turning itself off
Just had the Amani service guy out. Had the same problem. It was the capacitor. Took about 15 mins to fix. The machine turns off to protect itself because it knows something's wrong
Posted on Jan 06, 2010
hvac1960
  • 2133 Answers
SOURCE: We have a spit system
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Posted on Jan 01, 2011
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
I'm looking for an enigma split system airconditioner manual-I have an error message E5 with no compressor activity
E5 Communication errorbetween outdoor and indoor. Check output (call) from your indoor unit to out door unit by Volts meter. If no power in out door, you have to check setting of temp whether it's 23 and less than that and also mode in "Cool".
If power is there in out door and fan only running means compressor is tripped by overheated
Dec 16, 2010 | Heating & Cooling
Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Oct 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
Jan 05, 2009 | Heating & Cooling
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
