Question about Microwave Ovens
My refridgerator always leaks water. I have turned down the climate control to 5 and cleaned out the pan. Any suggestions
    President:
  • 1,796 Answers
Hi!! Can you provide the make and model of your unit please?
Posted on Sep 29, 2010
Magic chef 990W microwave clock keeps resetting. What is wrong and how can I fix?
Make sure that the program controller is receiving power - step down supply. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Since the clock is resetting it is a fault on the main board and the processor as it is tripping. So check power, check for faults mentioned above on the board. Also if there is fault of the magnettron leak or a waveguide leak then clean and check insulation.
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Sep 23, 2011 | Magic Chef MCD990W Microwave Oven
We have water leaking from the back of the frige, coming from under the area where the copper tubing connects from the wall to the actual refrigerator. I can't identify exactly what's leaking. I doesn't...
This can be an auto defrost condition. If your fridge is auto defrost, what happens during the defrost mode, ice build up is heated (in the area immediately near the evaporator coils, not in the main area) . This ice becomes water and drains out via a small tube, typically at the back or bottom of the machine. This water normally goes into a pan under the fridge, and evaporates without the user being aware of it.
If anything causes excessive ice build up (opening the door too much, door seal leak, etc.) then you get too much water and the pan overfills and spills out.
I suggest that you remove the pan from under your fridge, clean it, and put it back, and test to see if yo actually have anything wrong, or not.
This leak would NOT be refrigerant, as you would cease cooling if so. it is all condensation, which is physics and normal...
Mar 20, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
We have an 8 year old Alessi Nespresso machine, and it is leaking water at the base. It seems to leak only when the machine is in use. There is not any water at the base of the water container, so i am...
I have the same model, same age, same problem. It appears to be the seal between the metal heating coils, and the plastic switch that selects steam or coffee. Possibly caused by no cleaning the injector hole with the tool provided with machine (which causes a lot of back pressure). On mine, the screw that holds the switch to the heater has corroded and can not be unscrewed, so not possible to access rubber seal, and repair. May be tricky since this is plastic sealed to hot metal with a rubber gasket. So fo now, i unscrewed the black base plate on the bootom, and set the Alessi in a tray. THen just wipe up water after use.
Dec 27, 2010 | Microwave Ovens
I have an intergrated fridge freezer and the water keeps freezing over the little hole at the back then the water drips down the back of the fridge into my veg drawer I have turned the temp down but this...
Common problem with fridges. Suggest you get behind the fridge and somewhere on top of the compressor, there is a small pipe that normally sits in a pan of a sort. You need to blow hard into the pipe which will release the blockage in the system and that will clear the line. Water will then start draining again onto the compressor. That will stop the water build up in your fridge.
Aug 08, 2010 | Microwave Ovens
Water leaks from the bottom the ice maker is not hooked up and the pan under the refrigerator is not full freezer is not sweating neither is refrigerator side
whats this got to do with a micr wave?? But in reply to your question,, if the pan is always full under your Fridge, your evaporator isn't working correctly
Aug 02, 2010 | Microwave Ovens
AMANA UPRIGHT FREEZER LEAKS WATER FROM THE DOOR
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | KitchenAid Architect II KBHS109SSS...
Turns on randomly Reads: PAN and then counts down from 3 minutes
From the owner's manual found here or here:
"Touch PAN HEAT once. Pan will preheat for 3 minutes."
Sounds like it's doing it on its own due to a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 13, 2008 | KitchenAid KHMS145KSS Microwave Oven
Microwave turned off
I always suggest that the hood / exhaust fan be on whenever you're cooking on the stove top. This helps keep grease and steam out of the controls.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise, you may have a bad controller, which we may be able to repair for you.
Jun 29, 2008 | GE JVM2070 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
