Question about Sewing Machines
Thread tension dial on riccar sewing mach. needs repaired
The dial was turned 360 degrees, the spring clip popped out.
  • auntbug May 29, 2008
    1. help my upper tension adjuster knob came off of my Necchi 535fa, and I do not know in what order to put the parts back together. If anyone could tell me in what order to place the parts on the machine it would be very much appreciated.
  • Anonymous Sep 04, 2008
    I am using a riccar machine and the thread will not stay in the little handle that goes up and down .Do Ihav eit threaded correctly
Necchi 535A -- please help! I don't know in what order to put the upper tension parts back together on my sewing machine.
Posted on Mar 30, 2009
    Problem Solver:
  • 26 Answers
Please, tell me, is the main spintle, still on the machine, or it came off with the rest of the parts?
If you can put the tension parts, the one next to the other in front of the machine, and upload a photo for me, it will be very easy to explain how to put them back.
Posted on May 30, 2008
Need manual instructions for Riccar 2910 need help with bobbin, threding machined and tension setting and bobbin holder.
You may be better off going to google and search "riccar 2910 manual" That way you can follow their detail dorections rather then someone elses and it confuse you. Usually the PDF versions have pictures with it :-)
Apr 07, 2016 | Riccar Sewing Machines
Elna 6005 - I need to move the tension dial to 9 to get an even stitch. I re-treaded the machine and bobbin and it is still the same. Any solutions?
it is common when threading a machine for the top thread to get behind the tension plates and not between them
this makes it bind up on the mount bolt and gives false tension settings
even threads also depend on the bottom thread tension which is adjustable by the tiny screw that holds the spring clip that you pass the thread under when you put the bobbin back in the case
try going google --type in-- workshop manual for elna 6005 --and see if there is a pdf version available,
Sep 06, 2015 | Elna Sewing Machines
I have a VX1250. I don't know how to regulate the tension.
There is two places to adjust thread tension: the top tension device controls the top thread tension and is usually a dial or knob with numbers on the front of the machine.
Then there is some form of tension device on the bobbin; in your case I believe the Brother has a removable bobbin case with a tension spring which holds the bobbin thread firmly: the tension spring can be adjusted with a screwdriver but once set, you shouldn't need to adjust this much, just alter the top tension slightly for different weights of fabric. So start by setting top tension dial to 4-5 and test stitch a seam. Use different coloured but the same type of thread top and bottom and take a look at the seam. You want to see a balanced even seam.
Here is a link to a great info site for this:
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If the bobbin thread is too loose, then you probably will need to finess the tension spring on the bobbin case and adjust this slightly. The best way to set the tension on the bobbin case is as follows. Load the bobbin into the bobbin case and pull the thread tail into the tension spring, then suspend the bobbin by holding the thread tail up in the air (the dangle test). You want it to be just tight enough to hold its own weight, but still able to release thread when you pull gently downwards on the bobbin case. If it isn't doing this then take your little screw driver and adjust the screw on the leaf tension spring by ONE QUARTER TURN ONLY. Lefty looser, Righter Tighter. Then test again, and adjust again until its right.
Now test stitch again and finess your top tension to get the seam even. Remember to change the needle for each new sewing project too; this will impact tension also.
Jan 04, 2012 | Brother Sewing Machines
I have a Kenmore 385.16126200. The tension is too loose. I have already turned the dial all the way to 9. Is there something else I could do?
I would check to make sure the spring is working in the dial, check to see if the dial is actually closing around, if not could be a bad spring in it. Also check to make sure the thread is totally in the dial. Hope this helps.
May 16, 2011 | Kenmore Sewing Machines
Need to know how to thread a 550 super stretch Riccar sewing machine?
  • Unthread the machine.
  • Raise the presser foot.
  • Turn the handwheel until the take-up lever is at it's highest position.
  • Set the upper tension dial/knob to 5.
    The threading path is as follows:
  • From the spool around the top guide, down through the right slot, up the left slot, through the eye of the take-up lever from right to left, down through the guide(s), through the needle from front to back.
Nov 09, 2010 | Riccar Sewing Machines
UNDER THREAD NOT CATCHING
Hi, This is a threading problem.
When you thread the machine, to make sure it is right in the top tension, thread as far as the take-up lever and stop.
Set the presser foot down, turn the top tension dial to zero, and then to 3 or 5. While turn the dial, pull the thread some to see if it tightens up as the dial increases in numbers.
After the thread comes out of the tension discs, it should then go through the check spring, then up to the take-lever.
The needle is correct and thread from the inside out, meaning right to left.
Hope this helps for now..
Take care
Feb 18, 2010 | Tacsew 20U43 Sewing Machine
Hello I have an old Riccar 6800 sewing machine
Hiya, the threading for this machine is pretty standard so you won't be going wrong there. Have you used a sewing machine before? The tension dial (on the extreme left) should be set at 5. The other dial to your left should be on blue zigzag with orange broken line. The dial on the right should be set at 0 and the bottom one on 2 - 3. I've been looking for a manual for this machine as I inherited this one. It took me ages to suss straight sewing out. Another thought is take it to a repairer and ask for a quote. Good luck.
Nov 20, 2009 | Riccar Sewing Machines
White 2999
It looks like you have no tension on the bottom thread. Make sure the bobbin thread is in the tension spring, and that there is no lint under the bobbin tension spring. You may just need to increase the bobbin tension, it is one of the two small screws on the tension spring itself (not the one on the end, the one in the middle).
Try an online repair tips site to see what this all means if you need to.
Jan 31, 2009 | White Sewing 2999 Mechanical Sewing...
Brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Oct 21, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
267 people viewed this question
Top Sewing Machines Experts
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
