Question about Jenn-Air JCD2290HES Side by Side Refrigerator
My refrigerator seems to run for extended periods of time. It is currently 4 years old. I am looking to vacumn the lint/dust from the coils but am unable to gain access. Is there a preferred method to clean the coils on ths model? Thank you.
  • Jenn-Air Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 29, 2010
Frig and freezer has quit cooling. This unit is only 7 years old and has been cleaned of lint and dust every 3-4 months. I am not very pleased with Whirpool, I bought 5 appliances at the same time 7 years...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 19, 2010 | Refrigerators
GE Side-By-Side Refrigerator Stops Cooling
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Goodluck..
May 27, 2008 | Refrigerators
Not cold enough,it is 53 F in fridge and 18 F in freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 10, 2010 | Amana ABB1927DE Bottom Freezer...
Upright Frigidaire Freezer, Model#: MFU14F3GW9 It's approximately a 7-9 year old upright freezer. I believe the door may have been left cracked for an extended period of time, but I'm not positive....
if the doors shut okay,and there is no frost,and it is maintaining a steady internal temp(-18C to -20C) why worry.......anything else is going to cost money.......
Apr 05, 2010 | Freezers
10 year old side by side fridge is slowly not cooling well
Well poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils - Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system- defrost timer, defrost thermostat (also called the bi-metal switch) or the defrost heater.
Secondly you can check Condenser - Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Maytag Refrigerators
How do i clean the fan and filters,what cleaning does it need? welderslag@g-mail.com
At least once a year you have to pull the refrigerator out,unplug the refrigerator, remove the lower back panel, vacuum out everything you can get to, and then here is the tricky part. You have to use an air compressor to blow the lint, dust, pet hair, etc. off of the condensor coils and everything else back there. There is no other way to clean these well. This saves you a lot of money in added run time as the dirtier the coils, the longer the refrigerator runs. If you have a lot of pets that shed a lot, you will have to clean this 2 to 4 times a year. When I looked up the parts breakdown on here I did not see a filter, so I am assuming you are talking about the condensor, which is what the condensor fan motor sucks air through to cool off. Also clean the front kickplate at the same time. Good Luck Appliance Specialists
Jan 05, 2010 | Whirlpool ET8MHK Top Freezer Refrigerator
Refrigerator is 7 years old. no ice is being made and refrigerator is now setting on the "coldest" setting, and barely keeping refrigerator cool and freezer items barely frozen. could dirty coils be...
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 13, 2009 | Roper RT18HDXKQ Top Freezer Refrigerator
Rooftop a/c not cooling as well as it used to.
How old is this unit? In the Duo-Therm Brisk Air Models, they were notorious for a small leak in the capillary tube that runs into the evaporator part of the AC. There are two small tubes that are run together, take the top off of the evaporator coil and pull the lines apart gently. Look for noticeable signs of leaking in the area. If the lines have been looking or look like they have rubbed together for an extended period of time, you need to have someone replace the lines or buy a new air conditioner. I would price both before committing to either one. Hope this helps.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Fridge motor runs for extended time before briefly shutting down.
about the only thing you can do is check the coils located either underneath the unit or behind it. they will have a fan that directs air over them to disapate heat. these become clogged with an incredible amount of dust over time and extend running time. u can go to a hardware store and purchase a coil brush for under ten dollars it is long and thin to remove dirt from the coils. use a shop vac also. hope this helps. please rate me
Jan 12, 2009 | Refrigerators
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
52 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
