I have had a 32" vizio TV since May this year; which of late has started having these unclear and fluidlike images. What could be the cause and what can be done to rectify the problem.
    President:
  • 2,777 Answers
It is definitely a screen issue with the actual TV. Does this occur on all inputs? Meaning while watching TV, DVDs, and anything else attached to the machine? Since it was just purchased in May it will be under full warranty still. Where did you purchase the unit? If it was Costco for example you can still return it directly to the store for a full refund and get a different set.
You definitely have hardware issues going on with the TV, unless it is only on one input such as TV and not with DVDs, then it would be the source. But this sounds like the TV is the problem, and you will want to RMA it.
Thanks
Tim
Posted on Sep 29, 2010
Whats causeing ghost image on vizio e390i-a1
don't know this item but guessing its a tv and ghosting on tv is usually initially an antenna problem.
Sep 25, 2016 | Vizio L32 32 in. LCD HDTV
Where is the vertical hold control located on Vizio 32" 720 TV? Trying to give directions to handicapped brother remotely
there are no vertical/horizontal adjustments on this vizio lcd tv.
these functions are controlled by a microprocessor circuit and are not adjustable.
Jan 21, 2015 | Vizio L32 32 in. LCD HDTV
Distorted Image smart vizio tv 32 inch
It sounds that the T'Con board has failed. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 30, 2013 | Vizio E322ar
I have a tv lcd vizio and no turn on just the vizio lights
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 16, 2011 | Vizio E322VL 32 in. LCD TV
Vizio 32'' VO320E Image Distortion
I hope not but:
this is probably a failure from the screen or the electronic parts that control the videosignals.
i think having a specialist or the tecnical service from vizio taking a look at it will be best and safest.
Hope this is helpful, and greetings,
Olivier.
Oct 21, 2009 | Vizio VO320E LCD TV
Vizio 32 no power
http://www.encompassparts.com/models/?VIZVW32LHDTV10A justmanuals.com
do some research, pick out a weekend, and then replace that power board! save yourself some $$$ but make sure you order the right part and know what you are doing before you start.
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
My visio tv stoped turning on lately.
Hello threefreecol, This is a common problem related to the capacitors on the power supply board. What you can do is to take the back off of the TV and look to see if any of the capacitors on the power supply board are bloated or puffy (signs of damaged capacitors). If they are change them out with new ones (you are going to need a soldering iron and a desoldering pump to do this). In any event this is a power supply problem. I believe your TV is still under warrenty, so you may want to take it to a shop the honors the VIZIO warrenty program. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 12, 2009 | Vizio L32 32 in. LCD HDTV
Tv has a distorded image on right side
You have a speaker too close to tv,or some other stong magnet move the tv our magnetic source.
Mar 12, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
