Question about Poulan Garden
Have a bolens weedeater with a walbro carberator.it is getting gas to carberator, firing. but want start. put gas directly in carb, will run till gas runs out.
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
My powermate rear tine tiller is getting gas into the oil it will start and run as long as im am putting fuel into the carberator once i stop putting fuel the engine stops what is the problem. the til
This sounds like the float is sticking in the carb causing it to flood . You need to take the carb off and clean it and put a kit in adjusting the float per the instructions
Jun 27, 2014 | Powermate 18 in. 196 cc 4-Cycle Rear-Tine...
Newly rebuilt Walbro carberator is leaking fuel from the tank. Will leak till tank is dry.
there's a tiny little piston valve called a Float valve inside carb just above the Bowl (cup) this shuts off fuel when engine is not using it ,im gonna say thats your problem this usually requires a little adjustment to get it right , ck out my youtube video on adjusting carb floats for my tip's n triicks on how to do this
Apr 25, 2014 | John Deere Garden
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
I have a 25 cc Craftsman weedeater. Using fresh 40:1 gas. I've replaced the fuel lines, cleaned in tank filter, cleaned and rebuilt carb and getting spark, but it still won't start. Also cleaned...
the other possibilities you have is a bad crank seal, or a flywheel came loose and its out of time, will it fire on carb cleaner sprayed in the carb, If it runs for seconds and , then I would say it's not getting fuel, If it only farts once or twice then I would check crank seals cause if they are leaking then your crankcase cannot draw vacumn which in turn causes fuel pump in carb to draw fuel, If you have to check flywheel pull it apart and take flywheel nut off and pull flywheel off and inspect the key that is built into flywheel to see if it is sheared off or messed up, also while checking muffler check for the opening that the mud dobbers havent put mud in muffler pipe, good luck
May 15, 2011 | Craftsman 25cc Gas Line Trimmer
Blower must remain @ 1/2 choke in order to continue to run
You need to get a carb rebuild kit. there is a number stamped on your carb usually walbro carb it will be stamped WT# # ( # ) take that number to your local repair shop or on line and get a kit.
Nov 12, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
May 26, 2009 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
579 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
