Question about Cars & Co Richard Scarry's Cars and Trucks from A to Z
I have 2001 ford taurus 3.0 v-6, check engine light came on , Itook it to a local auto patrs store. They checked it and told me that the egr code was the problem. I replaced the egr valve and reset the computer, Check engine light came on once again. What next?
    Genius:
  • 1,340 Answers
Please read all of this.What I am suggesting is both a solution and not a solution.I get many bad ratings with this and I am serious,this is not a joke,but I will accept the bad ratings because it is truthful,factual,and very common.The check engine light has to be THE worst thing ever invented.There are so many things which can cause this light to illuminate that it is disgusting,both big and small.As long as your fluids are fine,your car is running fine,just put it out of your mind.There have been too many stories such as yours however,you got away cheap.A code comes up,people replace stuff which it suggests is wrong and what happens?That little $2 light is still glaring at them.Some people have spent over $1,000 and the same thing happens.Some forums I have read for fun,the people actually recommend putting black tape over the light because that is about what it is worth.I do not.I usually at least tell people how to check the transmission fluid because I do not know the level of knowledge of the people I talk to and it is very different than checking oil.With the engine running at least 5 minutes on a flat level surface,leave it running and dip the stick.Do it several times for accuracy.It should be within range just like the oil one.It's best to do after you came back from somewhere so you don't have to run the engine unnecessarily for 5 minutes.If there is no dipstick,it has to be checked by a shop or dealer.(Some current cars are like that).The trans. dipstick should be between the back of the engine and the fire wall.Any questions,reply back here and I will get an autolink to your post and reply ASAP.Good luck! Greg
Posted on Sep 29, 2010
2001 taurus lx engine light wont go off (EGR)
If you are getting an EGR code with the "check engine" light, and you have replaced the EGR Valve already.... please be aware that the DPFE sensor will also give and EGR code as well, you may want to try replacing it and try clearing the "check engine" light again.
Hope this helps...
Aug 25, 2011 | 2001 Ford Taurus
2001 ford taurus engine light blinks, the car sputters, I changed the IAC valve but still runs the same way, what's the next step ? could it be a misfire problem.
the next step is to have your computer codes read. This will help you identify the problem. most auto parts store will check it for free.
Feb 05, 2011 | 2001 Ford Taurus
My check engine light just came on, whats that mean?
means it is a ford taurus. probably going to be a misfire cylinder 1 & 2. take it to your local autopart store and they will pull the code for free.
Jan 06, 2011 | 2001 Ford Taurus
I took my moms 2001 ford taurus to be inspected. It fail due to EGR sensor.. Machnic said sensor needed to be cleaned. After taking apart he said valve was badly cloged. Soaked overnight and said it would...
I would highly suspect the "EGR backpressure sensor"
From experience and many conversations, a clooged EGR valve is almost unheard of these day. Get to an auto part store, were they can tell you what problem code(s) your car is getting, and possible good advice.
Sincerely, another 2001 Taurus owner.
Sep 20, 2010 | 2001 Ford Taurus
My 1990 3.0 taurus stumbles when i start to move. The check engine lite comes on when the stumbling occur's
I would have a local parts store like Auto Zone check the stored codes. Those codes will help direct you to what part is causing the problem, and making the light come on.
Apr 28, 2010 | 1994 Ford Taurus
2001 ford taurus with check engine light on. code
Make sure you replaced the right one there are two sensor's for the coolant, one takes coolant temp and the other one runs the fans for the radiator. Both are located on drivers side of the block. 2 wire leads on each how ever both are different in sending readings to the computer.Both look just alike also. Just make sure you replaced the right one. Or replace both.
Sep 15, 2009 | 2001 Ford Taurus
01 Ford Expedition. Check Engine light and failed Smog check.
whoever installed the egr valve, if it wasnt you, just cleared the engine codes, thus giving you this problem once again. Get it scanned at autozone, and go from there.
May 18, 2009 | 2001 Ford Expedition
1996 ford taurus. The check engine light come on.
the check engine light just means you are not meeting emissions. not a biggie. go to an auto parts store that does a free scan and get the fault code before spending any money.
Mar 01, 2009 | 1996 Ford Taurus
Check engine light stays on 1998 dodge grand caravan
the EGR may intermittently stick open, recommend replacing it.
Feb 27, 2009 | Ford Shelby Cars & Trucks
Engine service light
The DPFE (Diferential Pressure Sensor)sensor is usually mounted on the engine and is connected to the pipe that runs from the exhaust manifold to the EGR valve with two rubber hoses. When the sensor goes bad, the Check Engine light comes on and typically sets any or all of teh following fault codes: P0171 & P0174 (lean codes), and/or P0401 (insufficient EGR flow). Nine out of ten times, the fault is not a bad EGR valve or a vacuum leak, but a bad DPFE sensor. A replacement costs about $112 at Ford, or about $48 at an aftermarket auto parts store.I hope this helps.
Sep 30, 2008 | 2001 Ford Mustang
Cars & Co Richard Scarry's Cars and Trucks from A to Z Logo
59 people viewed this question
Top Cars & Co Toys Experts
ray gallant
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
