Question about SanDisk Sansa e250 MP3 Player
Freezes, then Shuts Off
Hello, my Sansa Sandisk e250 has been broken for a while. When I turn it on, and it takes a long time. Then it makes me choose the language. If I try to play a song or fix a setting, it freezes and the screen appears with white horizontal lines, then resets itself and turns back on. So I cant download a firmwire because if I try changing it to MSC, it will freeze and reset itself. I can always try taking it to a store, but Im not sure which. Any help is appriciated. Thanks for you help.
  • Earl Boykins May 24, 2008
    Also, I cant regulary shut it off, I have to hold thepower button for a few seconds. If I try to regularly shut it off, it will reset and turn on again.
  • 8,596 Answers
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 24, 2008
How do I reset my Sansa e250?
For resetting Sansa e250 to factory settings:
Start from Main Menu.
Next select:
Settings (image of an equalizer)
Reset All
Yes
Having problems reading the language first choose yours, select:
Language is the 5th option after Settings
Change the language to the language you prefer
Jun 20, 2010 | SanDisk Sansa e250 MP3 Player
Sansa freezes
try inserting a microSD card when player is turned off then put it on...work most of the times...
Sep 10, 2009 | SanDisk Sansa e250 MP3 Player
Sansa sandisk is freezing up and not recognized on comp
hello =)
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
May 31, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 Freezing
Reset the player, then get the Sansa Recovery Tool from Sandisk's website
Sep 01, 2008 | SanDisk Sansa e250 MP3 Player
Broken screen
What do you mean,it show a broken screen,dose it say broken screen or is the screen broken?
Jul 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa sandisk
LOOK AT THESE WEBSITE FORUMS...THEY ARE FOR THE SANDISK SANSA PLAYERS
http://forums.sandisk.com/sansa/search?submitted=true&q=E250
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 freezes!
This should take care of it;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa e250 MP3 is buggin
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
Slow download of files
We got it to work by changing a setting in the Sansa itself - go into menu, settings, USB,a dn select MSB (something like that - the second option). Suddenly it worked!
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
56 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
